00 auto feels like it is not down shifting
![](https://maxima.org/forums/images/smilies/support.gif)
whenever i punch it at about 35 ish(that is the only speed i have punched it in a while) it seems like the car won't down shift. it just seems like the rpm's crawl instead of jump up there. anyone have any experience with the car not down shifting when you punch it? it does downshift when i come to a stop thought. the only thing i have is the matt blehm ground kit and GAB with K&N filter. it might just be the GAB though, i don't know
also, when it is cold it is doing a little slippage(my new word i made up) but after it warms up it works fine. so what do i need to do about getting the TCM fixed? cheapest route please and how do i verify it is the TCM
Originally Posted by icewake
I appreciate it. can nissan just use consult to see if the TCM is bad. i also found a sticky on how to reset the TCM for 02-03, will this work for 00?
there has been arguments on if you can "reset" or "reflash" or "reprograme" a TCM. according to the service manual and numerous service managers and techs i have talked to, you have to replace it. you replace it with the upgraded TCM from the 01.
i had a bad TCM and didnt realize it. it wore out my tranny and i had to replace it (under warranty). after the warranty ran out, i started getting the "slippage" and had to buy a new TCM.
It could also be the fact that your shift point is 40 and the tranny doesn't have enough time or the rpms are too high to downshift effectively. My '03 has always been a dog at 35, 75, and 115 (not that I would know
![hide](https://maxima.org/forums/images/smilies/hide.gif)
Originally Posted by siren001
Would they still honor the slippage from a tsb in 00? Looks like I have to use my 100k bumper 2 bumper warrenty to change the wheel bearings and cv joints.
a TSB is simply a bulletin that lets the service department know how to correct the problem
well i was thinking about it and it probably isn't the TCM becuase it only slips when its cold(the tranny). i believe the TCM would make it do it all the time(just a thought) i am gonna change the tranny fluid again(did it about 3 months ago) and put some nissan tranny fluid in it. then if that doesn't work i plan on taking the TCM off my dads 01 max and put it on mine. and then finally if that doesn't work its probably the valve body. anyone agree?
Unclejunebug
04-02-2016 05:42 AM
hayne
10-05-2015 11:53 AM
