URGENT In midst of spark plug change
Old Nov 14, 2005 | 07:30 AM
kobalt's Avatar
I just pulled the first coil in rear bank and its covered in oil. Valvecover perhaps? What to do? Can I still change the plugs? Need help quick
Old Nov 14, 2005 | 07:36 AM
kobalt's Avatar
Update: pulled other two coils - no oil...
Old Nov 14, 2005 | 07:57 AM
AcerX's Avatar
Well if there isn't any oil on the other plugs then you've found the leak. I guess you might take off the cover and try and diagnose the problem. Can't say much else since I'm not there with you. Update this if you find anything.
Old Nov 14, 2005 | 08:08 AM
kobalt's Avatar
Thanx for the response. Pics soon...it appears that the ring/gasket on the inside of the valve cover was a bit moist with oil - so thats where the oil came from. Other coils and gaskets looked fine. I soaked the oil up as best I could with paper towel and will proceed to change the plugs. Will update soon.
Old Nov 14, 2005 | 08:12 AM
AcerX's Avatar
Okay, I'll be here till 11:00 AM Central time. Plus, you should use a old t-shirt or something not as fiberous to clean something involving your internals. Just my 2-cents. Trust me when I say its all I got.
Old Nov 14, 2005 | 09:05 AM
kobalt's Avatar
Thanx for the tip! I used my air compressor to blow out any possible paper towel leftovers (before removing the plugs of course) and finished off with a cotton rag. Want to see plugs with 140k on them? Stay tuned for pics.
Old Nov 14, 2005 | 09:48 AM
kobalt's Avatar
Just finished - no problems (so far). Some pics - I'll add comments when I return from school.
This was about 1/4 filled with oil
Like the bungiee holding the mainfold?
The culprit was the inner valvecover seal seen here moist with oil
Old Nov 14, 2005 | 09:49 AM
kobalt's Avatar
Another shot of the leaky seal
Made sure nothing could fall into the lower manifold
I had to wipe the valvecover down as the oil-covered coil pack was unexpected
Old Nov 14, 2005 | 09:50 AM
kobalt's Avatar
Front bank was completly dry
Old versus new
Plugs after 140k. Notice #5 was no worse than others
Old Nov 14, 2005 | 09:59 AM
AcerX's Avatar
Those plugs are in pretty good condition for having 140k on them. Only one that looks worn more so than the others is the bottom center plug. Which isn't even the one that had the leak.
Old Nov 14, 2005 | 10:00 AM
NmexMAX's Avatar
dot dot dot ...
Wow, those electrodes are gone ... Those are the stcok Pt units I take it?
Old Nov 14, 2005 | 12:57 PM
Matt's00MAX's Avatar
i ma about to do a tune up on my 00 auto max and i was wondering if NGK spark plugs for $7 a piece are good enough or do i need to get better ones.
Old Nov 14, 2005 | 01:03 PM
steven88's Avatar
Need A Light?
dude...cylinder #5 was shooting out oil even with the spark plug/coil pack still in place?
i see alot of oil from the pics your showing me...
Old Nov 14, 2005 | 01:48 PM
kobalt's Avatar
Just got back from school. I can't say drivability improved too much, but it seems a bit stronger down low. I'll see what changed with time. Its just unbelievable that the car ran super-smooth, got 28-29 highway mpg and did a 1/4 in under 15 seconds with plugs gapped as much as .086
Old Nov 14, 2005 | 01:50 PM
kobalt's Avatar
Mine lasted 140k - I would say that's pretty good for $7
Old Nov 14, 2005 | 01:51 PM
kobalt's Avatar
Luckily the oil came from the leaky valvecover seal, not the cylinder. I was a bit freaked out when I first pulled that coil.
Old Nov 14, 2005 | 02:16 PM
NmexMAX's Avatar
dot dot dot ...
And you confirmed this I take it?
Old Nov 14, 2005 | 02:24 PM
MaxOctane's Avatar
Oil shouldn't be in the combustion chamber period. If there is, it will burn up before it leaks out of the spark plug hole. If oil was coming up from the cylinder and leaking past the spark plug than you've got some serious issues. Oil in the spark plug well almost always means a leaky valve cover seal and won't effect the performance of the car at all. I don't know why one would have expected that spark plug #5 would look any different either - the oil in the spark plug well was not getting into the cylinder, and if it was, the spark plug would have to have been pretty loose...
Old Nov 14, 2005 | 02:29 PM
NmexMAX's Avatar
dot dot dot ...
Thats why I posted, because if it was merely a bad gasket, not that big of a deal, but being how it was concentrated in that one cyilnder area, that would have me concerend.
Old Nov 14, 2005 | 02:31 PM
kobalt's Avatar
Yes I have. I examined the spark plug and found oil on the top first 2 or 3 winds of the threading from the base. This would indicate that the oil accumulating in the coil/plug cavity seeped ever so slightly into the threading. Had the oil come from the cylinder area, the the entire threading would be covered in oil, especailly in the electrode area. I did not find any evidence of oil there. But I did find the inner valvecover seal saturated in oil which collaborates my findings.
Old Nov 15, 2005 | 02:35 PM
misiek's Avatar
thanks for the pictures!
sorry i cant put any inout for you
but the pictures helped with one of my projects!
Old Nov 15, 2005 | 08:04 PM
kobalt's Avatar
Misiek let me know if you want high resolution ones, I'll email them to you
Old Nov 15, 2005 | 08:14 PM
NmexMAX's Avatar
dot dot dot ...
And what might that be?
Old Nov 15, 2005 | 08:38 PM
k2max_driver's Avatar
Ahh... I see you too have discovered the leaky valve cover that plagues our maximas. I too had the problem but i discovered it at 30k when i changed my plugs. why did i change them? simple i was bored and had some free ones sitting in my garage. But yes getting back to the valve cover, Nissan decided to use plastic valve cover gaskets which tend to leak. Solution, replace them with new rubber ones from any parts store. Or you can ***** (to your local Nissan Dealer) like i do. But then you have to explain how you found out the they were leaking. Anyways now i dont have any oil in my plug resevoir and i know this cause i recently swapped out my NGK R's for NGK Iridiums.
Old Nov 20, 2005 | 09:26 AM
ABS's Avatar
ABS
I also had this problem when I changed my plugs around 75k. You actually have to replace the entire valve cover as the leak is coming from the rubber seal between the valve cover and the metal spark plug access tube. I also disassembled my coil to clean out any oil that had gotten into it. If you do this last step, just be careful, there are a few small parts which "pop out" when the rubber boots are removed and you won't want to lose them.
Old Nov 20, 2005 | 05:24 PM
ZeRo MaX's Avatar
i'm changing mine this weekend and hopefully this won't happen...
do you have to replace the entire valve cover or just the rubber seals?
Old Nov 20, 2005 | 11:00 PM
siren001's Avatar
is there any way to feel if its leaking while driving? without tearing it all apart?
Old Nov 20, 2005 | 11:05 PM
kobalt's Avatar
Im afraid not. But not to worry as the leak itself is harmless. Once the spark plug well fills with oil the leak stops and thats it. All the leak does is cause a bit of a mess while changing spark plugs.
mvm062
Nov 30, 2020 09:00 AM
knight_yyz
Nov 6, 2015 02:34 PM
ag90fox
Sep 9, 2015 12:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
