jic hight adjustment question
Old Nov 15, 2005 | 12:11 AM
super6's Avatar
the directions that came w/the kit have to be wrong because they make no sense. they say u adjust the hight by adjusting the spring perch, this cant be right, that would compress the spring and it spesifically says no to ver compress. so how do u adjust hight??? i figure its by the bottom adjustment nut right?
and how do u determine how low it is. i want about 1 inch drop, so i figure the max drop is 2.5 so ill screw them 1.5 inches down from that??
Old Nov 15, 2005 | 12:42 AM
steven88's Avatar
Need A Light?
loosen the spring perch lowest of the coilover....then spin the whole shock body into the lower mount...i believe its clockwise to go lower...counter clockwise is to go higher...after you are done spinning, lock the spring perch back into place
Old Nov 15, 2005 | 01:02 AM
super6's Avatar
ummm, what?? wich one do u mean by lowest of the coilover?
Old Nov 15, 2005 | 01:06 AM
steven88's Avatar
Need A Light?
there are 3 spring perches on the whole coilover...loosen the lowest one
Old Nov 15, 2005 | 06:44 AM
ColdSHO's Avatar
if u havent put hem ont he car yet, measuret o make sure the lefts ad rights are the same height, its alot easier to adjust them together b4 everythigns on, if theyr on already then,well grab a yardstck to make sure everyhtings even.
aw11power
Oct 10, 2021 04:57 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
