storing the max for 3 months?
Old Nov 16, 2005 | 01:34 AM
jay929rr's Avatar
well i'm storing the max for the 3 coldest months of winter. Is there anything i should do besides change oil and pull the battery to make sure she'll start ok in the spring?
Old Nov 16, 2005 | 03:58 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
give her a kiss...... make sure you turn it on and off... every week so the engine turns...
Old Nov 16, 2005 | 08:51 AM
deiz2k
when i store mine i use fuel stabilizer and i make sure i have like a half tank...i dont no if its does anything but she runs lovely every april...i did disconnect the battery and i started it ever 10-15 days...let it run for 10-15 min...bump my stereo a lil...then let her go back to sleep for a lil...
Old Nov 16, 2005 | 09:02 AM
MaximaPolak's Avatar
If you have a heated garage, blast it to 90º.
Old Nov 16, 2005 | 09:57 AM
NYPD-Arnold's Avatar
Z
Yeah just make sure you periodically start the car and let it run for a bit.
Old Nov 16, 2005 | 10:00 AM
Progress's Avatar
It's business time.
Get it some therapy as it will be confused and depressed because you aren't driving a FWD, four door econo-sporty car all year round.
Old Nov 16, 2005 | 10:58 AM
jay929rr's Avatar
I actually wasn't planning on starting it at all is that step really nessessary? It will be in a storage unit not by my home thats why i don't want ot be starting it.
Old Nov 16, 2005 | 11:11 AM
Progress's Avatar
It's business time.
In that case just unplug the battery and leave it at that. It will be fine through the winter. Just baby it when you start it in the spring.
GL
Old Nov 16, 2005 | 11:14 AM
Z
Yep, you'll have to re-break it in then if you don't start it.
Old Nov 16, 2005 | 11:15 AM
brianjh's Avatar
I would definately go with a fuel stabilizer, over time gasoline can break down & seperate !
Peace B
Old Nov 16, 2005 | 11:19 AM
rbrown81's Avatar
But why is teh Rum gone?
I have to leave my baby for a month from 20th december till 15th January in Jersey while I head to Australia for vacation.
Should i be taking any of these precautions?
Old Nov 16, 2005 | 11:29 AM
CCS2k1Max's Avatar
on the fuel stabilizer and oil change, and let me add a couple more thoughts.
Get a good quality car cover. If power is readily available, I'd leave the battery connected and just hook it up to a battery tender. It will extend the life of your battery. Other than that, I'd spray some silicone on all the rubber seals to keep them from sticking and put dessicant inside the car to keep the interior dry (and thus keep it from molding). Don't engage the parking brake.
Old Nov 16, 2005 | 11:56 AM
AcerX's Avatar
Make sure you turn it over(the engine,for any smart@sses out there) a few times each month and don't leave a lot of gas in the tank so it doesn't gum up.
Old Nov 16, 2005 | 12:42 PM
SoonerFan's Avatar
Cletus
i'll be leaving mine for 6 months when i go to afghanistan in 2 weeks
i'm leaving it on base and a buddy is gonna go start it up every couple weeks. hes also gonna drive it around base for a few minutes to keep everything moving the way its supposed to. i figure that better then just starting it and letting it idle. plus it will get the engine up to operating temp to keep the coolant moving
Old Nov 16, 2005 | 01:45 PM
doublea's Avatar
Good luck with your trip to Afghanistan, it's one place I wouldn't go, but you must be a soldier so I respect guys like you it take courage to go there.
Cheers
Old Nov 16, 2005 | 01:50 PM
jay929rr's Avatar
How will leaving a full tank of gas in there make it prone to gumming up?
also, i wouldn't think a fuel stabilizer would be needed for 3 months of storage right??
Old Nov 16, 2005 | 02:04 PM
AcerX's Avatar
[QUOTE=jay929rr]How will leaving a full tank of gas in there make it prone to gumming up?
It doesn't make it prone to gumming up. Having less gas in the tank just decreases the chances of it gumming up.
Old Nov 16, 2005 | 02:15 PM
Kevon1's Avatar
Yep.............. in Jersey if your leaving it a month you might want to take your Headlights with you.
Old Nov 16, 2005 | 06:24 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
I would recommend disconnecting the battery, leaving a half tank or less of gas, putting in fuel stabilizer and you should try to start it once in the middle of the winter and then when you take it out just give her a little while to warm up and get going before you drive her hard.
good luck,
-steve
Old Nov 16, 2005 | 06:38 PM
Mass_Media's Avatar
Mass_Media™
Re-break it in? like keep rpm's under 4k? stuff like that? im putting mine in my grandma's garage, so I won't be able to start it every so often. Im going to take the battery out and change the oil.
Old Nov 16, 2005 | 08:22 PM
Army of Maxima's Avatar
Looking for a few good Maximas
Sooner... be EXTREMELY careful about leaving it on base somewhere. Unless it is under 24/7 guard detail, those lots are prone to vandalism and high amounts of theft (the people KNOW that you are gone for a long time). There have been several cases on a number of different bases of this... and a lot of time, it is from another unit on post that knows your deployment schedule.
Good luck in Afghanistan - going with a Guard unit, you can expect to see a lot of tower duty, ECP, or QRF. Not fun, but makes the time go by.
_R
Old Nov 17, 2005 | 09:41 AM
Playero's Avatar
Sanduguero
Where are you stationed?
Old Nov 17, 2005 | 09:45 AM
GBAUER's Avatar
One thing not mentioned: run the A/C while you let it run. Sounds strange in the winter, but the hoses need to be kept moist so they don't dry out and crack come summer. Normally, the defroster use takes care of this for most people.
Old Nov 17, 2005 | 03:01 PM
SoonerFan's Avatar
Cletus
_R
the parking lot is right next to the LE (law enforcement) building. the lot is well lit with 24 hour video survelliance. someone would have to be stupid to do something to my car right next the cops with M-16s
im actually Air Force and we dont do tower duty im an "analyst" and will be working inside. i do have to carry my weapon and wear vest and helmet when outside.
Old Nov 17, 2005 | 03:02 PM
SoonerFan's Avatar
Cletus
pentagon but i'm leaving it on Bolling AFB
Old Nov 17, 2005 | 03:03 PM
SoonerFan's Avatar
Cletus
true.
im leaving a checklist for the guy who will be driving it around a little. it will include full heater and full A/C. it will also keep the freon (spl?) good and keep all the vents from getting musty
Old Nov 17, 2005 | 03:46 PM
GBAUER's Avatar
true.
Who's driving it around? Gayson? If so, I hope your insurance is up to date!
Old Nov 17, 2005 | 05:48 PM
SoonerFan's Avatar
Cletus
read my first post. a buddy of mine works on base.
since its on base im able to reduce my insurance to the bare minimum!!
Old Nov 17, 2005 | 06:48 PM
irish44j's Avatar
retired moderator
since I can get on base at Bolling, and work 2 miles from there, I'll swing by to T.P. your car once a week. (and I can pull rank on the MPs )
Old Nov 17, 2005 | 06:52 PM
Italiano's Avatar
SWIFT_Navigator
gl over there, my unit doesnt deploy to iraq till sometime next year..
Old Nov 18, 2005 | 07:05 PM
UGH. Another REMF.
I've been Infantry for over 18 years now... but we do appreciate guys like you... I'm an analyst (GIS Manager) in my 'real' job...
Old Nov 18, 2005 | 07:19 PM
irish44j's Avatar
retired moderator
I'll continue sitting in my office in DC making sure you guys on the ground (and sea) know what to shoot at.....
Old Nov 18, 2005 | 07:31 PM
SoonerFan's Avatar
Cletus
weak civilian
while you are sipping lattes with a tie on i'll be a war hero ACTIVELY protecting our countries freedom. and making/saving lots of money
Old Nov 18, 2005 | 08:00 PM
irish44j's Avatar
retired moderator
weak civilian
whatever dude...you do exactly what I do in your job....but you'll be sitting IN a BUILDING in Kabul doing it in front of a computer there, instead of DC. You're a desk jockey just like me, except you have to wear a uniform while I can wear jeans and a t-shirt if I so desire
(and don't forget, I outrank you GG-13/132 = Air Force Major equivalent)
Old Nov 18, 2005 | 08:51 PM
weak civilian
Whoa, wait... explain that to a friend of mine who was in a Humvee that got fragged by an IED... explain to him how your sitting behind a desk protected our country's freedom.
MaxLife17
Sep 8, 2015 02:36 PM
TheMafia
Sep 4, 2015 08:26 AM
trungg86
Sep 4, 2015 04:58 AM
meccanj98
Sep 3, 2015 08:58 AM
iflexsteel
Sep 2, 2015 08:04 AM
