leaking cv boot...will this fix work??
Old Nov 18, 2005 | 02:13 PM
super6's Avatar
the boot itself is very good, no crack, its leaking grease where it meets the axel, maybe a bean size amount per week (for about 4 weeks). its most likely due to that metal clamp being loose or something because the boot seems fine.
i wanted to know will putting a hose clamp or even better maybe a strong zip tie on it stop the leak or can it cause further damage to the boot
here are a few pics i took the leak, its on the left side of the axel on the first pic. http://www.sounddomain.com/ride/570891/2
Old Nov 18, 2005 | 03:11 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
the clamp should do the work........ keep an eye on it... if it doesn't well might have to replace the boot
Old Nov 19, 2005 | 08:51 AM
super6's Avatar
bump, can anyone advise??
Old Nov 19, 2005 | 11:20 AM
chr0nos's Avatar
if there is still grease leaking out, the cv join should be good, and putting a hose clamp will fix the problem. make sure the old hose clamp did not cut into the boot itself with a sharp edge, and that's the reason for leaking. i would get the same type of clamp as you have now. they have a different fastening mechanism, and will not come loose. the standard hose clamps have a screw, and it may loosen over time.
Old Nov 19, 2005 | 01:39 PM
super6's Avatar
what i did was just place a new screw type clamp over the old one, made if fairly tight, i didnt want to start cutting the old one n maybe damage the boot.
Old Nov 19, 2005 | 02:19 PM
RA030726's Avatar
I'm nutty for Nissans
you can buy the actual CV boot clamps, but they usually need a special tool to be installed. i have had a dryer clamp on my outer boot for months with no ill effects. it will work perfectly fine.
Old Nov 19, 2005 | 05:51 PM
super6's Avatar
how do u take the original claps off, do u have to cut them off or they pry off somehow?
Old Nov 19, 2005 | 08:04 PM
betcha618
just buy a new axle theyre like $50.00 bucks. solve all ur problems. Sometimes spending a lil more money is worth not having the aggrivations.
Old Nov 19, 2005 | 08:34 PM
super6's Avatar
well what i did was, take off the old clamp, and put on a new screw type clamp. i dont know weather to make it really tight because i dont want it to eat into the rubber. guess ill see how it goes.
Old Nov 20, 2005 | 12:33 AM
Maxn2theMax's Avatar
I had the same issue of excessive grease leaking out...so far the screw hose clamp has worked. Only thing i found out is that on one clamp, the screw started to work itself out. I used some thread lock, and about 20K miles its' holding.
jerrod99_se-l
Aug 27, 2015 08:27 PM
FlaMark
Aug 21, 2015 11:06 AM
carlosvq30
Aug 17, 2015 11:32 AM
kenc15
Aug 5, 2015 08:29 AM
