Gear lube or tranny?
Old Nov 19, 2005 | 05:01 AM
zoner's Avatar
Hey, has anyone out there on the .org experienced shifting problems with the Amsoil Series 2000 75W-90? Just curious. While it shifted smoother and easier when cold, shift action got pretty notchy after the tranny got good and warm - even to the point that I crunched 3rd once on a normal upshift . I used to use the regular Amsoil GL4 75w-90 with no problems.
I went back to the the regular GL4 75W-90 last night, and shifting seems to have returned to normal. Any ideas on what's going on?
Old Nov 19, 2005 | 09:19 AM
MaxOctane's Avatar
Is the Amsoil Series 2000 75W-90 GL4 or GL5? You definitely don't want to run anything but GL4 because GL5 has too much extreme pressure additives and will corrode your copper and brass metal parts. It's also more slippery and might cause your synchros to slip and could cause the crunching you are experiencing. I've been running Redline MT90 GL4 and have had no problems. I get perfecty notchy shifts with no grinding. I've been wanting to switch to Amsoil GL4 because I hear Amsoil is better in preserving tranny life where Redline is more geared towards performance.
Old Nov 20, 2005 | 07:32 AM
zoner's Avatar
It's supposed to have GL4 EP additive levels, but offer the protection of a GL5 - so it's safe for a trannys requiring only GL4 or GL5. I believe they've taken it off the market for a newer versions that are GL5 only.
Old Nov 20, 2005 | 07:33 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I have the newer version GL4, no problems here...
Old Nov 20, 2005 | 04:54 PM
zoner's Avatar
The newer version GL4 is what I put in and shifting seems to have improved, so I wouldn't be too nervous about it.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
