installed jic, getting squeeking in rear
Old Nov 22, 2005 | 08:02 PM
super6's Avatar
installed last week, tighned, adjusted evrything, got alighnment. there were really no noises. just started to get a low pich squeek in rear, souds like its commin form rear mounts or struts themselfs. everything is tight, what could it be?
only thing i can think of is that the lowest coil is rubbing the coil above it because they are pretty much touching (on bottom and top of strut) but i cant do anything bout that. if ill lower the bottom perch they really will not be tight in their seats. anything else it could be?
Old Nov 23, 2005 | 11:33 AM
super6's Avatar
bump......................anyone w/advise
Old Nov 23, 2005 | 11:38 AM
ColdSHO's Avatar
ur spring coils are touching?
is ur rear suspension seem really stiff? if so
sounds like ur lower spring perch is too tight, ur rear springs are probly copressed to much, id say take the two upper collars and unscrew them to the point where the spring is loose and re preload them, the colloar soudl be snug but not compressing the spring.
that should do it!
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
ef9
Aug 27, 2015 07:21 AM
maxipower
Aug 21, 2015 11:10 AM
Maxboy23
Aug 20, 2015 09:33 AM
