easiest way to install clearance bulbs
Old Nov 23, 2005 | 02:10 PM
MxdOut97's Avatar
ive looked around and found nothing, but if there is a write-up on this just direct me and end it at that. anyways, im trying to install some polarg's for my clearance bulbs in my headlights and was wondering if removing the headlight would be easiest to do this...its pretty tight in there. Any suggestions?
Old Nov 23, 2005 | 02:19 PM
irish44j's Avatar
retired moderator
find someone with a small hand, I guess....
I just changed mine last week. It's tight, but all you have to do is twist the bulb holder out, change the bulb, and twist it back in....
Old Nov 23, 2005 | 02:22 PM
MxdOut97's Avatar
alright thanks
im guessing i should turn it counter clock wise just like a screw right?
Old Nov 23, 2005 | 02:31 PM
irish44j's Avatar
retired moderator
as I recall....it should turn pretty easily.
Old Nov 23, 2005 | 02:42 PM
NYPD-Arnold's Avatar
Z
Clearance bulbs? Are you talking about the bulbs above the turn signal? If so, yeah, those are a pain to twist out. I personally twisted mine off, took out the bulb, and drive without them. Looks much cleaner that way. =)
Old Nov 23, 2005 | 03:58 PM
NJ Devils Fan's Avatar
Those suck as far as changing. I've had to change mine several times. After the first time, my passenger headlight was stolen so I ordered a pair of piaas. Once you get them in, you won't be angry anymore because they look so nice.
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
Maxie40
Sep 14, 2015 11:28 AM
minsbang
Sep 11, 2015 08:48 PM
