Is there anyway to aim our fogs?
Old Nov 23, 2005 | 10:56 PM
OutMaxxed's Avatar
Like the title says. I just want it aimed up just a tad bit higher so i can see them. Any suggestions?
Old Nov 23, 2005 | 11:13 PM
steven88's Avatar
Need A Light?
yes, just take off the foglight and there will be an 8mm bolt you must turn...i just recently did mine...
counter clockwise aims higher...clockwise aims lower
Old Nov 24, 2005 | 02:55 AM
Bluesbrekr's Avatar
Doctorate in Detailing
I'll have to check that out again. I thought the adjusting bolt adjusted them from side to side and not up or down.
Old Nov 24, 2005 | 05:52 AM
Puppetmaster's Avatar
Btw, good info here as well:
http://forums.maxima.org/showthread.php?t=441242
Old Nov 24, 2005 | 09:12 AM
NYPD-Arnold's Avatar
Z
You don't need to take the fogs out. I had mine adjusted to point all the way up. Improves visbility a ton, lights up the signs A LOT further and I never, ever get highbeamed. Now I can actually tell when my fogs are on or off.
Old Nov 24, 2005 | 09:56 AM
steven88's Avatar
Need A Light?
naw it's up & down...trust me...I just recently did mine so I still remember...
oh yeah, I don't know if its just me, but I took out my housing to adjust that bolt....there might be a way to do it without taking out the housing...I just took mine out becuz you can't see **** down there!
Old Nov 24, 2005 | 10:37 AM
OutMaxxed's Avatar
is the bolt on the foglight housing it self?
Old Nov 24, 2005 | 10:38 AM
steven88's Avatar
Need A Light?
yes.......
Old Nov 24, 2005 | 12:16 PM
bebandit's Avatar
Adjusting....
I bought OEM fogs from Custom Maxima site, they have a PDF of the install instructions which on the last page shows you how to aim the fogs after installation. If I remember correctly, all you would have to do is take the plastic guard out from the front tire well (a few grommets and a screw - 2 seconds) and then you should have access to the long-thin adjuster.
If you can't find the PDF (i think it was Custom Maxima) let me know and i'll scan my instruction book, I kept it somewhere.
Old Nov 24, 2005 | 05:35 PM
Maximax2's Avatar
It's hard to explain - after you take the splash guard off you can get to the foglight adjuster, but it's inside the foglight housing. IIRC, there's an X-d area (like you see on a soft drink top for the straw), and that's where you put the screwdriver. On mine I had to break through, then could adjust at will - no problems in many miles of driving.
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
