Newest Generation short shifter opinions
Old Nov 23, 2005 | 11:04 PM
SEturner's Avatar
Hello all,
I did a google search of this site, but could not find anything recent regarding the newest short shifters.
Since the introduction of the originals, both the Watkins/HP/Active Tuning/Cattman shifter and the TWM shifter have changed. They both now leave the shifter centered in the pattern.
What are some opinions about which one is best (solid, smooth, effort is not much greater, etc.)? One is a two piece design and one (TWM) is one piece.
The TWM is also much less expensive, so if it performs as well, that is the one I want to buy, if not, I will go with the Watkins.
Old Nov 24, 2005 | 01:53 AM
zachary1988's Avatar
I bought the 2 piece from Active Tuning because it was cheaper of the bunch. Very easy to install and definitely centered the shifter. Initially, I installed an extra washer so it was very, very difficult to shift. But after talking to the deisgner, he immediately knew the problem and I corrected it. Now it shifts as it did before. TWM recently changed their design but if I recall correctly from one of the members I read, he stated that the shifter was not positioned in the center.
Old Nov 24, 2005 | 02:47 AM
Bluesbrekr's Avatar
Doctorate in Detailing
I have one of the original HP single pieces (anodized black). Yes, it does move the shifter forward a bit, but I rather like it that way. It allows my arm to clear the armrest better.
IIRC TWM is the source company for the HP and Wadkins pieces.
Old Nov 24, 2005 | 05:47 AM
Puppetmaster's Avatar
My Watkins (2 piece version) shortens the throw nicely and centers the shifter pretty much perfectly. There seems to be no adverse effect on shifting whatsoever and is even better now that I've sprayed the bushings down with white lithium grease. My Energy Suspension poly bushings will be in sometime soon and I'll replace the stock (busted) bushings as well and see how that works for me.
http://www.fast-shift.com/
I don't the TWM units are the same because even though they claim that their single piece centers the shifter, chr0nos, who got his TWM recently, apparently had to buy the 2nd piece from Watkins to get it centered.
Old Nov 24, 2005 | 07:39 AM
SoonerFan's Avatar
Cletus
i have the Watkins two piece one too and love it.
joel, i told you that you would like it
Old Nov 24, 2005 | 07:48 AM
rbrown81's Avatar
But why is teh Rum gone?
Im going to do the bushings at the same time as I put in the shifter just to save the trouble.
Puppet : All you need to do is coat the bushings with lithium grease?
Old Nov 24, 2005 | 08:15 AM
Park2670's Avatar
The Ultimate Driving Machine
I have an HP STS and its centered and really shortens up the throws
Old Nov 24, 2005 | 08:49 AM
SEturner's Avatar
I am unable to search posts by chr0nos, but in his profile he indicates he has a Watkins/TWM short shifter. I thought those were the two competing designs, not the same one? Did he switch from Watkins TO TWM or is it just a mistype?
The TWM is $109 now and the Active Tuning $159.
Old Nov 25, 2005 | 06:58 AM
Yeah, I like it so far without the ES bushings, so hopefully when those come in my sentiments will remain unchanged. I guess a lot of lithium grease and some breaking in should do the trick.
Old Nov 25, 2005 | 07:01 AM
Get the white lithium grease in aerosol form and not the paste kind that Soonerfan had initially...
You just have to spray the inside of the bushings and the maybe also the shifter ball thing (sorry, can't remember the tech term) at the bottom of the shift rod. Basically all the components that may be hindered by excessive friction. You have my IM, lemme know if ya have any questions later, but it should be pretty easy to figure out once ya see it.
Old Nov 25, 2005 | 07:03 AM
Like I said in my post, chr0nos bought the single piece TWM for $109 but found that the throw were shorter but the shifter was not centered, so he bought the 2nd piece from Watkins to center the shifter.
Old Nov 25, 2005 | 09:04 AM
Peabo5000's Avatar
So which is the the 1st/ 2nd piece? 1.under the hood/under intake 2. under center console inside car.
Old Nov 25, 2005 | 09:13 AM
Using your numbering:
1. "First" piece - shortens throw distance
2. "Second" piece - centers shifter
Old Nov 25, 2005 | 11:38 AM
Deckdout2's Avatar
Play with my balls
When you make your way down here, I want to compare yours and mine. I just want to see if they are the same throw or if one is shorter than the other.
Old Nov 25, 2005 | 11:47 AM
I'll let ya know when I can come down....
Wait a minute here... I hope you're referring to our STS's, you feg.
"I want to compare yours and mine. .... or if one is shorter than the other."
Old Nov 25, 2005 | 12:05 PM
silvermax2k2's Avatar
Old Nov 25, 2005 | 12:12 PM
Originally Posted by silvermax2k2
Old Nov 25, 2005 | 12:21 PM
Deckdout2's Avatar
Play with my balls
Uhhh, no comparison needed, we all know who's slong is bigger.......
Old Nov 28, 2005 | 06:15 AM
chr0nos's Avatar
i got the twm, and after having it for 2 weeks, i got the second peice from brian catts to re-center my shifter. the twm peice is great, it just relocates the shifter forward.
replace your bushings with ES bushings at the same time, i would use the regular gray self-lubricating bushings. there is absolutely no point in getting the red ones that need grease. people will nerver see the inside of your shifter mechanism.
i kept the OEM bushing inside my engine bay, and just replaced the ones inside the cabin. the STS shortens your pivot ponint, and it's harsher on the shifting mechanism, the softer oem bushing takes some of the stress off the shifter cable. i dont know if there is a big difference in between the ES poly and rubber OEM, but i left it for peace of mind.
REDinLV
Aug 15, 2024 12:30 AM
mkaresh
Mar 12, 2018 06:48 PM
BobTX10
Oct 7, 2015 08:43 AM
atriuum
Sep 28, 2015 01:19 PM
