Never seen this before
Old Nov 26, 2005 | 08:16 PM
fiveyearsdead's Avatar
Hello to all,
I recently purchased a 2000 se with a 5-speed. All four calipers are sticking. I did some extensive searching and could not find any info on this matter. I did install a new caliper on the left front to see if by some strange twist of circumstance, the calipers themselves were to blame. However, the problem still persists. This leads me to believe that there is either a problem with the master cylinder or abs unit. Also, there are no warning lights for the ABS. If anyone can shed some light on this, please feel free to share your thoughts. Thanks in advance.
Old Nov 27, 2005 | 01:33 AM
MaxPol74's Avatar
I had the same problem with the back left caliper and the problem was the rusty/stuck brake line.
Old Nov 27, 2005 | 07:58 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
do a whole system flush.. and lubricate all brake components, if the brake seals are broken.
Old Nov 27, 2005 | 12:01 PM
upstatemax's Avatar
I had a problem with my rear calipers sticking, when I replaced my pads, lines and rotors I also cleaned the calipers really well and flushed all new brake fluid in... have not had a problem since.
Old Nov 27, 2005 | 02:21 PM
bert's Avatar
I just had a right rear done, under extended warranty.
Old Nov 27, 2005 | 05:30 PM
BewstAdd1ct's Avatar
how many miles on it?
if more than 60K, id say lines also.
Old Nov 27, 2005 | 08:16 PM
getbigtony's Avatar
instead of flushing, first bleed them. might be that simple; if it persists, then flush.
Old Nov 27, 2005 | 09:21 PM
upstatemax's Avatar
If it has the original fluid it is not a bad idea to flush the system... It cost under $10 and takes under an hour to do.
Old Nov 27, 2005 | 10:20 PM
I believe I have narrowed the problem down to either a faulty master cylinder, or ABS actuator. My buddy drove the car to the point where the brakes would stick, and then I opened different lines until the wheel would break free. The tests show that the master cylinder is more than likely to blame, but I can't entirely rule out the ABS. I thought about a full flush, but the fluid looks and smells fine. Also, I had already bled the left front when testing the caliper theory. Thanks for the replies.
