a/c pully bearing Q
Old Nov 27, 2005 | 02:47 PM
Greeny's Avatar
¯\(°_o)/¯
a/c pully bearing Q
Hey guys:
I am working on a friends 2000 gle..The a/c compressor pully bearing is shot..My question is does anyone know a good parts source for the bearing...Advance auto parts website shows a bearing for it but i don't trust them for the right part..Pic of bearing on the compressor below..
Thanks in advance for any help..
Old Nov 27, 2005 | 02:52 PM
foodmanry's Avatar
Da Roller Coaster!
Usually non-name brand bearings will last just as long as a bearing from your dealer. They are all pretty standard.
Old Nov 27, 2005 | 03:39 PM
Bensmax00's Avatar
in the past i have jsut replaced the whole compressor clutch--never had any problems with them.
Old Nov 27, 2005 | 03:51 PM
Greeny's Avatar
¯\(°_o)/¯
I am trying to save them some $$$ by just replacing the bearing..The whole compressor is quite pricey[from $100 used to $350 new]..I just want to know if anyone has knows a good reliable place to buy the bearing besides advance auto..thank for suggestion though..
Old Nov 27, 2005 | 05:38 PM
BewstAdd1ct's Avatar
no, just the clutch. if you want to get the right bearing for sure, youll proabbly be going to the dealer, and a clutch assy aftermarket might run you about the same.
Old Nov 27, 2005 | 05:51 PM
Greeny's Avatar
¯\(°_o)/¯
Yeah..I am starting to think dealer for the bearing too.. I was hoping someone in here knew a different vendor for the part..The advance auto parts in my area has nothing but incompetent morons behind the counter..
Old Nov 27, 2005 | 07:38 PM
JamesNH's Avatar
the bearings in the pulley correct? BUMP! Might need this info.
Old Nov 28, 2005 | 12:10 PM
98tothemax's Avatar
comes with clutch assembly $335 from nissan $365 and you get the compressor as well
Old Nov 28, 2005 | 12:13 PM
Jeff92se's Avatar
I'm needing a caw
IF you can read the bearing p/n, you can get a bearing place to x-reference it. But you need to press out/in the new one. So you have to get the pulley off the compressor. You might be able to get it off with a puller if you have enough room
Old Nov 28, 2005 | 12:39 PM
Greeny's Avatar
¯\(°_o)/¯
I will try to get you that PN. this evening...Thanks jeff..
Old Nov 28, 2005 | 12:40 PM
Jeff92se's Avatar
I'm needing a caw
nonononono. If YOU can read the p/n, YOU can call a bearing place and see if THEY can x-reference it.
But I can check if you like. You can usually run the p/n on the net to see see what's up.
Old Nov 28, 2005 | 12:44 PM
Greeny's Avatar
¯\(°_o)/¯
Sorry, misread your post...I got 10 things going on at the same time here at work,...And trying to read your post too
Old Nov 28, 2005 | 12:48 PM
Jeff92se's Avatar
I'm needing a caw
Aren't you banned?
Old Nov 28, 2005 | 12:49 PM
Greeny's Avatar
¯\(°_o)/¯
Aren't you banned?
Everyday...
Old Nov 28, 2005 | 02:06 PM
Greeny's Avatar
¯\(°_o)/¯
The bearing is made by NSK bearings..The part # 35BD219DUK..
Old Nov 28, 2005 | 07:25 PM
JamesNH's Avatar
CAn anyone confirm the part number and the size specs on this page http://www.kml-bearing.com/public/pu...ontent=catalog
Old Nov 29, 2005 | 01:44 AM
Greeny's Avatar
¯\(°_o)/¯
It x references with AC355520 part# on there site...
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
EdRomo86
Sep 12, 2015 07:49 PM
