2000 maxima gxe making a whinning noise somewhere in the engine when i turn it off.
Old Nov 29, 2005 | 09:49 AM
zmaxuser's Avatar
This problem is driving me nuts..when i turn the car off, it makes this whinning noise from somewhere in the top back portion of the engine...and when the car is in park..and i hit the accelerator, the car makes the whining noise and it stalls..any ideas?
Old Nov 29, 2005 | 09:53 AM
96sleepergle's Avatar
could be your belts or rusty idler pulley, also check the alternater
Old Nov 29, 2005 | 04:19 PM
Inspiron's Avatar
The noise is probably the motor mount.
The stalling can be a bad MAF.
Old Nov 29, 2005 | 06:14 PM
zmaxuser's Avatar
My mechanic cleaned the MAF, the car ran better for a little bit...but now the RPM drops even on drive, which it never did before...maybe it's time for a new maf? i never thought about the motor mounts..do they make a whinning noise when car is turned off?
thanks
Old Nov 29, 2005 | 06:25 PM
Inspiron's Avatar
Cleaning the MAF will not fix it.
I am not positive but I think it's the motor mounts that make the noise. It should only last a few seconds right after the car it turned off.
Old Nov 29, 2005 | 06:33 PM
zmaxuser's Avatar
i will tell the mechanic to replace the maf...and yes the noise only last about 2 or 3 secs..after the car is shut off..so the mounts need to be replaced?
Old Nov 29, 2005 | 06:34 PM
5thgenmaxima's Avatar
Every tech thread a read- someone is saying--replace your maf or "I just replaced my maf, that wasn't it). - I'm still not able to start a new thead, awaiting activation or something..tick tock.....Anyway's there is a way to test your maf before just throwing money at it. There are probably--(at least on all mafs ive seen) 4 wires coming from maf. One is a power wire, one power ground, one signal, and one signal ground.(If my memory serves me correctly) I'm sure it's posted here somewhere how to check the maf signal with a voltmeter before replacing. Do some searches, I honestly wouldn't replace something knowing it's probably not the cause......
....Maybe I'm making the parts suppliers/moderators mad in here and their not activating my nic????
Old Nov 29, 2005 | 06:46 PM
sascuderi's Avatar
Bad electronic motor mounts can do this. Read this TSB, it may help:
http://maxima.theowensfamily.com/tsb/NTB01-010.pdf
Old Nov 30, 2005 | 06:09 AM
zmaxuser's Avatar
I think you are right on the money...that is my problem..the buzzing sound..I will call my mechanic now and let him know about this TSB. thanks a lot.
Old Nov 30, 2005 | 07:13 AM
Mark2's Avatar
What is the risk if you do not replace your Bad electronic motor mounts?
Old Nov 30, 2005 | 10:23 AM
zmaxuser's Avatar
mechanic stated that the noise came from the engine mounts..but he did not recomend for me to replace them.if i can deal with the noise..he said it would do no harm..to keep them.
Old Nov 30, 2005 | 02:59 PM
zmaxuser's Avatar
My mechanic was able to find the maf here locally for $83..he replaced it..and now problem has been solved..no more stalling at all in parking or neutral...I not changing the engine mounts he said..it was no big deal..
thanks for all your help..
Old Nov 30, 2005 | 05:58 PM
paralyse's Avatar
I Miss My Maxima
5thgenmaxima:
We speak from experience. When you've been here awhile, you can question the wisdom of the other 5,000 victims of crappy Maxima MAFs.
BTW, post whoring is lame, and will get you a
Old Nov 30, 2005 | 07:00 PM
sascuderi's Avatar
No problem and my pleasure. Glad to help.
egali045
Aug 16, 2015 01:19 PM
jholley
Aug 11, 2015 09:38 AM
kirkhilles
Aug 8, 2015 10:53 AM
bassmann
Aug 3, 2015 07:53 PM
