WTF....Auto Climate Controls are STUCK in Econ mode!!! Anyone has an idea?!?
Old Nov 29, 2005 | 08:50 PM
2001SE's Avatar
I started the car today, and the when I pressed auto it would not activate it. It was just stuck on Economy mode, and I am not able to turn the speed of the fan any higher or lower with the manual bottons. JUST the **** for the temperature works and it changes the speed of the fan.
Its dangrous because if I need to use the defroster to clear the windshield, and that doesnt even work.
what do you guys think this is?! a fuse for the AC? should I disconnect the battary? maybe that could help?
I hope I wont need to buy a new one, the car is an 02 and only has 58k....wtf my 01 with 133k doesnt have this probelm
Old Nov 30, 2005 | 04:12 AM
2001SE's Avatar
BUMP
Anybody has any comment about this? I really need to get this thing fixed today, and I dont want to end up going to the dealership and giving to them 500 bucks for a whole new unit + "labor"
Old Nov 30, 2005 | 07:29 AM
Jasovanni's Avatar
I'm not going to pretend to be an expert here, but here's what i would do.
The econ button basically disables the a/c compressor, yet stilll allows the auto climate control. Your defroster uses the compressor, all do, so yeah, its pretty stuck. I figure it's either a glitchy control unit, or something having to do with the compressor clicking on.....
Try pulling your battery cable for a while, perhaps it will shock the unit back into working. Otherwise, my advise would be to perhaps even diagnose the compressor to be sure all is working. However, i'll be honest, unless you are really good at diagnosing electrical, you will prolly have to take this one in for diagnosis.
Hope this helped a bit!
J
Old Nov 30, 2005 | 08:55 AM
2001SE's Avatar
I pulled the battary cable for a while, that didnt work.
I am gonna try to disconnect it from behind by opening up the center console, and see if that will help it.
If not, then I am pretty sure I got a glitchy control unit.
This is so random
Old Nov 30, 2005 | 11:55 AM
bigsherv's Avatar
what does economy mode do again?
Old Nov 30, 2005 | 12:23 PM
alpinestars™'s Avatar
THIS IS...
I believe it turns off the A/C compressor and just brings in outside or circulates inside air.
Old Nov 30, 2005 | 01:34 PM
026SpdSE's Avatar
I have somewhat of a different problem, but it's kind of related, since it deals with the electrical system and apparently I don't have enough posts to start my own thread.
But anyways,
I have an 02 Max SE and I have read about the TSB regarding the sunroofing opening by itself. Has this happened to anyone else? I havent used my sunroof in MONTHS, but I get in my car this morning and noticed that the sunroof was cracked open like an inch. Will it continue to happen, since it happened once? I have 46K, so its no longer covered by warranty, but would it be covered by the TSB? Or is it even worth having the TSB done? I heard its due to corrosion on the electrical components causing the malfunction. Is this that big of a deal really?
Any help would be greatly appreciated! Thanks!
Old Nov 30, 2005 | 03:04 PM
2001SE's Avatar
You should call a few dealers around you to see how much they would charge to fix it. I am pretty sure its not expensive, so give it a try.
I suggest printing the TSB so they would exactly what you're talking about.
pktaske
May 6, 2016 07:49 AM
Starrider
Dec 18, 2015 04:43 AM
mikeg75
Nov 30, 2015 05:12 PM
pktaske
Sep 4, 2015 08:40 AM
