How often do you change brake pads?
Old Nov 30, 2005 | 11:54 AM
bigsherv's Avatar
Mine don't squeek but I am on 38K. Seems like I should have had them changed by now.
Old Nov 30, 2005 | 12:08 PM
igzy's Avatar
I Know Kwaliti
If it ain't broke - don't fix
If you do not have any vibrations while braking, you could look how much pad there is left of them by inspecting the pad vs. wear guard and it will be a good way to tell if you need to change them or not... I find that mine last me about ~30K including the way I drive...
Old Nov 30, 2005 | 12:14 PM
kcowden's Avatar
Just spent $400 on new rear rotors, pads, turned front rotors, and new ceramic pads with only 42k on mine. The rear ones were gone, probably due to towing my dirt bikes on my trailer.... Best thing to do is to have them checked out somewhere.
Old Nov 30, 2005 | 02:04 PM
Whtmax'01's Avatar
When I dont feel like taking off the wheels to check the pads, I just shine a flashlight on caliper where the pads sit and can easily see how much the pads have worn. I guess checking pads this way depends on how much space you have between the spokes of the rim.
Old Nov 30, 2005 | 04:46 PM
Rayn4est's Avatar
I'm going to look at mine when I put my winter wheel on (probably this weekend). I have about 30K and I expected them to be worn based on what the looked like when I took my winter wheels off this spring. We'll see. I'd like them to last until spring.
Old Nov 30, 2005 | 04:48 PM
cabernet's Avatar
My rears get 40K and my fronts get 60K
Old Nov 30, 2005 | 06:34 PM
k2max_driver's Avatar
i change my front brake pads just about every 3 or 4 months and my rears every year or so
Old Dec 1, 2005 | 03:48 AM
Rayn4est's Avatar
How do you get more out of your fronts than your rears?
Old Dec 1, 2005 | 03:53 AM
maximaownsyou's Avatar
seems that i have heard the rotors on maximas have problems and my rotors are slightly warped at 55k miles. im 40% left on brake pads too and havent replaced them yet
Old Dec 1, 2005 | 04:22 AM
paul5:14's Avatar
Carefull with the "they don't squeek" method of determining wear. Cause mine didn't squeek either then one day started grinding. When i did the breaks i came to find out the sensors had either been cut off or broke off. You should def. check them.
Old Dec 1, 2005 | 04:35 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
brake pads should last.. unless you drive like an a$$.... so just keep an eye on them....my front ones changed them twice.... factory ones and then the HAWKS for 3 years now and still going... rears twice too.. I have 98k miles on my 01
Old Dec 1, 2005 | 06:21 AM
igzy's Avatar
I Know Kwaliti
Yup, I am driving with third set of fronts now and second set of rears with 80K+...
Old Dec 1, 2005 | 08:01 AM
bigsherv's Avatar
thanks amigos
Old Dec 1, 2005 | 08:55 AM
maximo-SE's Avatar
my oems lasted till 20K, my raybestos QS lasted another 20, now im on my third set which is Axxis Metal Masters (worst brakes i've used thus far, squeeks like a biatch), im going back to OEM or Raybestos QS.
My rear rotors tend to wear longer than my fronts.
Old Dec 3, 2005 | 01:40 PM
Rayn4est's Avatar
I just put on my snow tires and the rears have about the thickness of 2 quarters remaining, the fronts about 3 quarters. The rears have about 62K, the fronts about 35K (I put on cross drilled rotors around 30K). I'll probalby replace them all in the spring.
Old Dec 4, 2005 | 06:29 AM
tasha's Avatar
I have to change my rear brakes soon they are grinding and Oh thats so Bad they squeek and all that good stuff 2. But I need to change them soon or im going to be sliding. hehe
Im also just learning about how long the brakes can go before you have to change them out on my Maxima. But pretty soon I might need rotors soon too but wont know until I take the rear brakes off..
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
A32goldylocks
Sep 2, 2015 06:39 AM
