cold start idle problem with 2000 gle..
Old Nov 30, 2005 | 03:45 PM
Greeny's Avatar
¯\(°_o)/¯
Hey again guys...
I am currently working on a friends 2000 gle with a cold start idle problem..Checked the computer for codes,nothing....Then i checked the spark plugs and they were pretty worn..
So i changed them,but it still idles like ****...The car will stumble pretty bad when idleing cold and will almost die,but it idles and drives just fine after it warms up...i did a search on this problem and come up with the maf being the culprit...
Any other thoughts..Thanks.
Old Nov 30, 2005 | 05:55 PM
paralyse's Avatar
I Miss My Maxima
Your search results are correct.
Old Nov 30, 2005 | 05:59 PM
zmaxuser's Avatar
I just replaced the maf on my maxima today it was stalling on park and neutral...problem fixed....=}
Old Dec 3, 2005 | 07:57 AM
Greeny's Avatar
¯\(°_o)/¯
Update: Replaced the maf.... It didn't fix it.. It still is stumbles at cold idle and almost dies when put into gear....It will accelarate smoothly when cold,It just idle's very rough...
Any idea's????
Old Dec 3, 2005 | 10:12 AM
darrick04's Avatar
Any idea's????
Not sure about the fix but I know mine does the same thing... I have checked my MAF, it's as clean as ever, and the last time I had it serviced it was fine, so I don't think this is the culprit!
Old Dec 3, 2005 | 10:26 AM
GBAUER's Avatar
Might be the coil packs.
Old Dec 3, 2005 | 10:32 AM
darrick04's Avatar
and I know coil packs have been mentioned hundreds of times on here, where is the best place to get them? how do you know if they go bad, like what do you check for?
Old Dec 3, 2005 | 10:58 AM
Greeny's Avatar
¯\(°_o)/¯
I read a bunch on the coil pack problem with the 2000 model, but from what i understand the coil pack/packs fails under load...The car does not stumble when you give it gas,only at cold idle...It doesn't do it after it warms up...
Old Dec 3, 2005 | 11:03 AM
BigL0U's Avatar
im having the same problem with my 01 ... quite frustrating. friends say the oil might be too thick n takes TOO long to warm up ... been puttin the same oil since i got the car. cant be it. wtf could it be?
Old Dec 3, 2005 | 11:05 AM
Whtmax'01's Avatar
I just changed coil packs today because yesterday car started to idle very rough felt like the steering wheel will vibrate into my hands. Yesterday i had no SES light, today however i had all three TCS, SLIP, SES lights and the problem stayed the same after the engine was fully warm.
Old Dec 3, 2005 | 11:10 AM
FoggyboTTom's Avatar
flowmeter?
Old Dec 3, 2005 | 11:12 AM
BigL0U's Avatar
call me stupid but whats a MAF so i know what im talking about when gettin it repaired?
Old Dec 3, 2005 | 11:13 AM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by FoggyboTTom
flowmeter?
http://www.forums.maxima.org/showpos...29&postcount=4
Old Dec 3, 2005 | 11:14 AM
Greeny's Avatar
¯\(°_o)/¯
Mass air flow sensor....
Old Dec 3, 2005 | 11:21 AM
BigL0U's Avatar
Whtmax'01 have you yet to replace ur MAF? ill be the guinnea pig (spell check) if needed.. cant be that expensive eh?
Old Dec 3, 2005 | 11:30 AM
BigL0U's Avatar
just got an estimate at a local shop... MAF for $103.58 from nissan...does that sound right?
Old Dec 3, 2005 | 11:31 AM
paralyse's Avatar
I Miss My Maxima
As I stated above, if your search has already revealed to you that the MAF is bad, replace the darn thing already and get on with it.
It's cheap insurance on a 2k. Price a 2k2 maf sometime.
In the (very long shot) event that the new MAF doesn't fix the problem, check for proper IATS and CTS operation. Problems with either of these sensors cause cold-start drivability issues.
Old Dec 3, 2005 | 11:37 AM
Greeny's Avatar
¯\(°_o)/¯
I just updated the thread this morning and said the maf didn't fix the problem...Read the whole thread before you get all snippy...
Old Dec 3, 2005 | 12:03 PM
Whtmax'01's Avatar
I bought the coil packs along with the MAF, i will install the MAF very soon. I just had to install the coil packs first because they seemed to worry me most.
I dont have that rough idle after new coils went in.
Old Dec 3, 2005 | 12:36 PM
brad1384's Avatar
2000 SE Stumbling
I own a 2000SE.The problem occurs only when cold. When I accelerate lightly (1800 rpm) it stumbles alot. I've replaced The MAF twice. The last being 13 months ago. I also had the coils replaced 8 months ago.What could be wrong?????
Old Dec 3, 2005 | 03:18 PM
paralyse's Avatar
I Miss My Maxima
Fair enough.
Coil packs, CTS, IATS; thermostat stuck open; IACV sticking open; TPS malfunction
Even a vacuum leak can cause this problem.
Old Dec 3, 2005 | 07:26 PM
brad1384's Avatar
Where do I start?
Old Dec 4, 2005 | 01:23 AM
the paragon's Avatar
change the starter. mine died out on me last week, bad idling as well.
Old Dec 4, 2005 | 06:34 AM
ZIPPIN's Avatar
Mauja He Mauja
when was the fuel filter changed last?
Old Dec 4, 2005 | 06:59 AM
sascuderi's Avatar
Had cold stumble problems with my 2000 I30. Replacing all six coil packs did the trick. Also, make sure air filter is not dirty.
Old Dec 4, 2005 | 07:25 AM
njmaxseltd's Avatar
Cold engine operation problems could come from a bad Engine Coolant Temp sensor.
A MAF problem should not be temperture dependent.
Old Dec 4, 2005 | 07:44 AM
nismo_star's Avatar
So much info, but lets start with the basics, clean throttle body on vehicle.
Does idle speed change after wards ? 650-750 OK, any higher and you need to go to the dealership. Have them perform Idle Volume Learn, and reset Self-Learn. At the same time, have them check to see if you have to have the ECM Updated ?
Does symtom reoccur ? Yes, airflow meter and if the air flow meter's part # is for the 'countermeasure' then it will need to have an updated program loaded.(if not done already.)
BTW sounds like your intake manifold gasket or vacuum hose is leaking if its cold, and idles messed up, and gets better when warmed up.(*hint* both expand when warmed up.)
Good luck.
Old Dec 4, 2005 | 03:34 PM
brad1384's Avatar
Thanks for all the help. I wanted to stay away from the dealer, but I guess I can't. The car does have a new air filter,MAF-13 months, new coils-8 months. Is this a common problem? ( stumbling when cold under light acceleration?)
Old Dec 4, 2005 | 04:03 PM
brad1384's Avatar
What's the proper way to clean the throttle body?? Is there a step by step guide? Thanks for the support!
Old Dec 5, 2005 | 08:15 AM
nismo_star's Avatar
Remove air box and tube spray a rag and clean the the throttle body, as the rag gets dirty flip to another side or if u can use another til u get all the carbon out.
Old Feb 7, 2011 | 08:17 AM
heathjudeh's Avatar
Iacv/ecm is probably the culprit
Old Feb 7, 2011 | 08:18 AM
heathjudeh's Avatar
open ecm and check for burn marks
heathjudeh's Avatar
also make sure and check the maf to make sure its clean and electonic motor mounts as well
Old Feb 7, 2011 | 08:27 AM
Shift_Max's Avatar
Iacv is my guess.
Old Feb 7, 2011 | 08:45 AM
VQ'rInWLA's Avatar
Another thread brought back from the dead
Old Feb 7, 2011 | 09:01 AM
Fail. IBTL.
tsi6001
Oct 3, 2022 10:23 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
FlaMark
Aug 21, 2015 11:06 AM
kirkhilles
Aug 8, 2015 10:53 AM
