With out paying the $400 at the dealer. Where can i get another MAF sensor?
At 68,000 miles this car is getting to be an expensive pain in the ***. I need a new Evap. control valve in the rear, mass air flow sensor AND brakes turned for the SECOND time.
DaveB - 888-254-6060
or some people use 2001 MAF which is less than $100 but I think it's not a direct replacement.
Quote:
Its easy.... Originally Posted by Indigo
Do you know how hard it is to replace it? Is it something fairly easy that i can do?
If ya wanna save some cash:
http://forums.maxima.org/showthread.php?t=348395
And stop going to the dealership.
You can also get them fairly cheap from courtesyparts.com Its easy to replace, 10 minutes max. 4 bolts, a clamp, and disconnect the wiring harness.
Quote:
Its even faster if you leave the tube in and just remove the two torqs screws, and pull the sensor out the top.Originally Posted by mtrai760
Just buy an 01 Maf, and swap the thermister out of the old one to the new one. $87 fix.
James
James
I though it was a direct plug and play?? I dident know you had to swap out the themister?Originally Posted by jimmycapp
Its even faster if you leave the tube in and just remove the two torqs screws, and pull the sensor out the top.Just buy an 01 Maf, and swap the thermister out of the old one to the new one. $87 fix.
James
Quote:
You can use it w/o the IAT, but it will throw a CEL. Originally Posted by danger300z
See link in post #5.
