Should there be play in the parking brake handle...
Old Dec 1, 2005 | 04:52 PM
NJ Devils Fan's Avatar
Should there be any play in the parking brake handle when it is not engaged? I have an auto and I always use my brake as to not put stress on my transmission. When it is not engaged, I can lift the handle quite a bit. Should I tighten it by engaging it and tightening that?
Old Dec 1, 2005 | 04:57 PM
DrKlop's Avatar
Driving is the next best thing
Yes, tighten it. I had the same thing before, until one day it started rolling and nearly hit my garage door.
Old Dec 1, 2005 | 06:48 PM
I just need to get one of those deep socket things because the screw part prevents the socket from getting to the nut.
Old Dec 1, 2005 | 06:56 PM
k2max_driver's Avatar
remember to drive in reverse and slow down with the e-brake to adjust the cables after tightening. Boy you just can't stop nitpicking about all the little stuff, wait til your tranny goes
Old Dec 1, 2005 | 07:41 PM
Haha, its the little stuff that make life worth living.......
Hmm, roll in reverse and bring her to a stop with the e-brake? Perplexing. Just need to do that once?
Old Dec 1, 2005 | 07:46 PM
Jime's Avatar
You do need the deep socket to adjust, but dont do it up too tight, make sure there is no pressure on the brakes when lever is down. Err on the side of caution.
Old Dec 2, 2005 | 09:21 PM
DUKEE's Avatar
yea it happened to me. i tightened a little too much and next thing you i smell rubber cause i had it tight enough that it was engaged while i was driving. oops ;(
Old Dec 3, 2005 | 07:37 AM
NisMoN00B's Avatar
+Cru OG
Where is this adjustment screw? I went to check on mine, and can lift the e-brake handle about 1/2"
Old Dec 3, 2005 | 10:23 AM
MaximaPolak's Avatar
Mine is has some play in it NJ Devils Fan. That's normal. The brake still holds me still on steep hills.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
