235\45\R17... can this fit on my stock 17" 2k3 rims?
Old Dec 9, 2005 | 07:07 AM
maximo-SE's Avatar
235\45\R17.... i have 225/50/17 so will it fit?
i want to buy a pair of nokian snow tires from my friend. thanks
Old Dec 9, 2005 | 07:12 AM
Puppetmaster's Avatar
Yes.
See the Rims and Tires section in the FAQs for pros and cons.
Old Dec 9, 2005 | 07:35 AM
maximo-SE's Avatar
hey thanks again man. always welcome your 2 cents
answer one more question for me: what does that 45 represent?
Old Dec 9, 2005 | 07:40 AM
45 is the sidewall aspect ratio. It is the sidewall measurement or height and it means that it is 45% of the width (the # 235). When tires are referred to as low profile, they have shorter sidewall height.
Old Dec 9, 2005 | 07:42 AM
Btw, this is a good site for reading up on these things:
http://www.tirerack.com/about/techcenter.jsp
This topic is covered under Tire Size Information.
Old Dec 9, 2005 | 07:59 AM
Derrick2k2SE's Avatar
It represents the height of the tire as a % of the width. A 235/45/17 will have a width of 235 MM, a height (rim to tread) of 105.75 MM and of course fit on a 17 inch rim.
Old Dec 9, 2005 | 05:36 PM
irish44j's Avatar
retired moderator
I will fit...but a good rule with snow tires is to go NARROWER than stock, not WIDER
I suggest you get 215/55/17 or just stock size.
Also, check Nokian's official specs....SOME 235/45/17 will fit on a 17x7 rim, and SOME will not...not all tires have the same block width and seam width.
Old Dec 9, 2005 | 06:00 PM
Good point... narrow snows are more effective than wide snows.
And are you posting on the .Org from Snowshoe?
alahjahwan09
18
Sep 21, 2015 09:12 PM
0m3nc0w
Sep 11, 2015 05:21 PM
Violator
Sep 9, 2015 10:14 AM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
