2k2-2k3 HLSD 6speed owners step in - weird issue
Old Dec 9, 2005 | 08:14 AM
MiniRX7's Avatar
I noticed in the rain, or snow, when you accelerate, my car always pulls right...
When i accelerate and my car brakes traction, no matter where i am the car goes right and i need turn the wheel to the left.
At first, when i had my 19's on, i thought it was the tires, but i habve new winter tires one, and it does the same thing.
Do you guys know what could cause this? I wouldnt be so concerned if the car drifted left or right, but always right makes me wonder.
I thought HLSD was suppose to give both wheels solid power to eliminate the open diff problems (which for sure would make the car drift)..
Old Dec 9, 2005 | 08:18 AM
Italiano's Avatar
SWIFT_Navigator
sounds like you need a realignment.. my car did this when i first bought it, had it realigned and now i can let my hands off the wheel and have it drive straight without a problem.
Old Dec 9, 2005 | 08:22 AM
Puppetmaster's Avatar
Just to point out, HLSD doesn't "give both wheels solid power". It transfers the power to the wheel with the most traction, as opposed to an open diff where the power takes the path of least resistance and goes to the wheel which is slipping. For example, you take a turn and the inside wheel starts slipping, the HLSD will transfer the power to the outer wheel to get you forward.
As for your issue, I don't know enough about this stuff yet, but I'll do some research later. I'm sure someone who knows more will chime in at some point.
Old Dec 9, 2005 | 09:14 AM
boondoxmax's Avatar
I think its normal cause its snowing here today and my car was doing the same thing. It seemed to pull slightly to the right/passenger side. I just figured it must be the wheel with the most traction so it give that wheel power causing it to pull slightly...
Old Dec 9, 2005 | 12:11 PM
00SEMAX19's Avatar
HLSD doesn't stop torque steer. Is this only when accelerating?
If not you have a problem with your alignment. Camber is not adjustable so get camber kits and you will be able to compensate for a pull.
Old Dec 9, 2005 | 01:13 PM
MiniRX7's Avatar
Well thats the thing, it only pulls to the right when both tires on are the same slippery surface. not just sometimes, but ALL THE TIME when the tires spin (ie snow). Never pulls to the left.
I had the alignment check and it is okay. I wonder if this may be a Defective HLSD...
Old Dec 16, 2005 | 09:30 PM
silverx's Avatar
Was HLSD a stock option on SEs?? How can I check if a car I am looking at purchasing has it?
Old Dec 16, 2005 | 11:08 PM
Max'dMatt2k3's Avatar
Easiest way is look at the pedals, 02-03 6spds had drilled aluminum pedals,
or just do a burnout....
two black strips = HLSD,
one wheel peel = no HLSD,
no wheels spin, but lots of smoke = no clutch
Old Dec 17, 2005 | 01:51 AM
MiniRX7's Avatar
No matter what, the car pulls to the right
dont get it
Old Dec 17, 2005 | 03:45 AM
HotshotVQ35's Avatar
car still under warantee? if so take it to the dealer. my 02 with HLSD doesnt do it..
dont get it
Old Dec 17, 2005 | 04:20 AM
http://forums.maxima.org/showthread....HLSD+transaxle
Old Dec 17, 2005 | 07:46 AM
silverx's Avatar
Thanks for the link.. I can't search yet..
pktaske
May 6, 2016 07:49 AM
I<3 A32's
Sep 10, 2015 11:07 AM
pktaske
Sep 4, 2015 08:40 AM
trungg86
Sep 4, 2015 04:58 AM
