Hhhheeelllpppp!!!!!!
Old Dec 11, 2005 | 11:46 AM
NOCturnalI30's Avatar
I blew a fuse or something but I cant find it. My door locks my dome lights my rear defrost and my lights on my door dont work anymore. Ive checked all of the fuses under the hood and in the cab with a multi meter. ANYONE ELSE KNOW WHAT IT COULD BE????? PLEASE HELP!!!!!
Old Dec 11, 2005 | 12:14 PM
shurik's Avatar
ahhhhhhhhhhhmmm...anyone know??? I don't.
Old Dec 11, 2005 | 12:47 PM
Whtmax'01's Avatar
it has to be a fuse under the dash. You checked every single fuse?
Old Dec 11, 2005 | 12:48 PM
yes dude i have i cant fig it out
Old Dec 11, 2005 | 01:09 PM
icewake's Avatar
maybe you just accidently overlooked one becuase goign through so many you end up just taking a real quick glance, just to be safe you might as well try one more time before you end up putting a good couple hours into it
Old Dec 11, 2005 | 01:27 PM
I did like 5 times. I was doing that freaking mod metal max did with the dome light and the whole this shorted out i guess the polarity was crossed and now nothing works
Old Dec 11, 2005 | 02:16 PM
MCE's Avatar
MCE
Go to the fuse block and use your multimeter to verify there is power on the one side of the fuse leg. If there is, again make sure the fuse is good. If it is, you probably fried a wire after the fuse. Good luck hunting this one down. You will have to use an ammeter and check each run.
mce
