Auto transmission solenoid pack
Old Dec 12, 2005 | 06:07 PM
whazzzzuup's Avatar
As the title states, I am looking for an transmission solenoid pack for my 2002. My transmission is slightly slipping from 2nd to 3rd. If you guys have an idea where to get one, please let me know. The AT light isn't blinking or anything. It started slipping out of nowhere. Can it be the TCM? If the TCM is faulty, will it throw a code?
Old Dec 12, 2005 | 06:35 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
1-888-254-6060
Old Dec 12, 2005 | 10:00 PM
NmexMAX's Avatar
dot dot dot ...
Mine was being from 1-2, got the VB mod, and it hasn't acted up since. (~10,000 miles)
Old Dec 12, 2005 | 10:35 PM
whazzzzuup's Avatar
How much is the VB mod? A solenoid pack is around $260 I think. Should I just spend the extra money for the VB mod? What is the average downtime on the car?
Old Dec 12, 2005 | 10:38 PM
NmexMAX's Avatar
dot dot dot ...
Are you sure it's the solenoid pack and not the VB?
400$, and it depends on if they have a VB ready for you so that your downtime is minimized.
www.maximumtuning.net.
Old Dec 12, 2005 | 10:41 PM
whazzzzuup's Avatar
I read somewhere yesterday that a slipping 2nd to 3rd gear shift is from a faulty solenoid pack or TCM. How do I know for sure? Will a damaged VB have the same symptoms?
Old Dec 12, 2005 | 10:53 PM
NmexMAX's Avatar
dot dot dot ...
I would get it diagnosed first.
Old Dec 13, 2005 | 08:57 AM
kcowden's Avatar
How hard was the install?
Old Dec 13, 2005 | 09:49 AM
NmexMAX's Avatar
dot dot dot ...
Use Lontar1's write-up for tranny drain, and then you'll see all the bolts.
Old Dec 13, 2005 | 08:19 PM
whazzzzuup's Avatar
How long did it take you to remove the VB?
Old Dec 13, 2005 | 09:59 PM
NmexMAX's Avatar
dot dot dot ...
You didn't read his write-up, located in his sig, about the tranny drain did you?
The mechanical portion is easy and doesn;t take that long ... it's waiting for the fluid to drain that't the most time consuming .. drink beer.
Total, 4 hours, but 3 of those were spent :
Old Dec 13, 2005 | 10:42 PM
whazzzzuup's Avatar
I've done 4 transmission fluid changes in 4 different Maximas already in the last 2 years. I am asking about the VB removal itself.
Old Dec 13, 2005 | 10:51 PM
NmexMAX's Avatar
dot dot dot ...
After the fluid is done draining, look up, there are IIRC 18 bolts that hold it in place...Loosen them and it should come off ...
Make sure when you re-install it, that all the o-rings re: the solenoids are put in place and do not lose any of them.( o-rings)
Old Dec 15, 2005 | 10:24 AM
whazzzzuup's Avatar
Thanks a lot. I was wondering if rebuilding the VB will also fix the solenoid pack? Is the solenoid pack a seperate unit? Is it outside of the transmission casing, or is it built within the VB?
Old Dec 15, 2005 | 10:26 AM
NmexMAX's Avatar
dot dot dot ...
How are you going to rebuild the VB?
The solenoids are internal, even moreso than the VB, you can see them when the VB comes out.
Old Dec 15, 2005 | 10:30 AM
whazzzzuup's Avatar
What I meant was sending the VB to www.maximumtuning.net. I am pretty sure it is my solenoid pack. I just found a picture of them. Okay, thanks again.
Old Dec 15, 2005 | 10:34 AM
NmexMAX's Avatar
dot dot dot ...
How sure.......?
Old Dec 15, 2005 | 12:14 PM
whazzzzuup's Avatar
I called Dave B and he said that it usually is the SP that is causing the slippage. The only reason why people usually replace the VB, other than for performance (e.g. maximumtuning), is because the SP replacement did not fix the problem. He also said to diagnose it will probably cost more than just buying a new SP. I really don't know exactly what it is, but he said a slipping 1-2 or 2-3 shift is most likely a result of a faulty SP.
EDIT: I still want to do the VB mod though.
Old Dec 15, 2005 | 02:12 PM
igzy's Avatar
I Know Kwaliti
How much did you get quoted for the solenoid pack from Dave?
Old Dec 15, 2005 | 03:23 PM
vsamoylov
let me know how much it was and i see what it costs at my dealer. might be able to get you a better deal.
Old Dec 15, 2005 | 04:14 PM
whazzzzuup's Avatar
That would be great, seriously. Dave B said $293 plus 7 dollars shipping.
Old Dec 15, 2005 | 04:20 PM
RR5's Avatar
RR5
What exactly is the VB and what does the modification address? I think my 02 slips from 1-2. Just to confirm, I'm accelerating and if I back off the throttle a little, it will not upshift. It just hangs at a high RPM for a few seconds, then shifts. If doing the mod will help that, I will be all over purchasing whatever to fix that.
Sorry for the questions.
Old Dec 15, 2005 | 04:30 PM
igzy's Avatar
I Know Kwaliti
That would be cool! Can you let me know too, thanks...
Old Dec 15, 2005 | 05:20 PM
NmexMAX's Avatar
dot dot dot ...
I do not think your tranny is slipping, it's because you let off the throttle, that's why it behaves as such.
If it does that during 100% WOT ... then you've got ptoblems.
For more explanation ---> VB = Valve Body --->
Old Dec 16, 2005 | 04:25 AM
kobalt's Avatar
Does anybody know what the labor costs would be for replacing the solenoid pack? Extensive or trivial?
Old Dec 16, 2005 | 07:32 AM
igzy's Avatar
I Know Kwaliti
Look up the TSB, it has details in it. I think it is in neighbourhood of an hour or so...
Old Dec 16, 2005 | 08:48 AM
whazzzzuup's Avatar
In this VB removal, it also shows how to remove the SP. A very easy process.
http://www.vqpower.com/v2/modules.ph...howpage&pid=60
Old Dec 16, 2005 | 10:34 AM
NmexMAX's Avatar
dot dot dot ...
Success story #1, the original thread starter goes on to give advice in his own thread.
Old Dec 16, 2005 | 01:16 PM
kobalt's Avatar
Thanx for the link, very interesting
Old Dec 21, 2010 | 07:26 PM
pevey's Avatar
MY 2002 ISN'T SLIPPING, IT SEEMS TO SHIFT HARD FROM 1-2, ANY IDEAS? MY MECHANIC THINKS IT IS THE SOLENOIDS. IT SEEMS TO GET WORSE AS THE CAR GETS WARMER, WEATHER DOESN'T SEEM TO BE A FACTOR, COLD OR HOT. I'VE ALSO BEEN TOLD IT COULD BE CRANK OR CAM SENSOR????
Old Dec 21, 2010 | 08:00 PM
trooplewis's Avatar
Da*m n00bie, you are not going to get a warm welcome here if you come out of the gate yelling at everyone like that. Learn some netiquette!
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
Tmax78
Sep 25, 2015 09:07 PM
