fuse?!
Old Dec 20, 2005 | 06:37 PM
Imax00's Avatar
fuse?!
i dont know but while i was installing my hid kit i think i messed something up. My parklights and taillights dont work anymore when i turn my headlights on.
I thought I blew a fuse so i practically tested all of those tiny fuses and replaced most of them and the problem went away, but now its back for good and no fuses are blown. what could be wrong?
Old Dec 20, 2005 | 08:00 PM
ope2k4's Avatar
I had the same problem too. By the way did you get a plug and play HID kit?
If its a plug and play kit then one of the wires must be touching metal. Then Im thinking youve got the kit with no high beam right?
Did you even use a tester when you were installing the HID kit? Improper splicing
causes this problem too.
You need to answer these questions so I could help you further
Old Dec 20, 2005 | 08:23 PM
RLLOGY805's Avatar
might be some kind of a short
Old Dec 22, 2005 | 08:39 PM
Imax00's Avatar
It was a plug a play kit, but one of my bulbs went bad and a buddy of mine who im almost sure is one of those people who **think** they know everything, he spliced a bulb of the same K into the wires and it works. So im guessing improper splicing? is there anything i can do to fix it?
Old Dec 22, 2005 | 08:44 PM
ope2k4's Avatar
Yeah thats the problem. He might have spliced the wrong wires or one of the wires is touching a ground. To check if they're right wires, use a tester. You could get one cheap at any autozone for 5 bucks. Test for negative(ground) on the spliced wire with light on low beam , the positive should turn the tester light on. if it doesnt then that means theres a problem with the splicing.
hope this helps
Old Dec 22, 2005 | 08:54 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Blown fuse is in one of two locations:
(1) Driver side panel in the cabin, check fuses #13 & #14.
(2) Under the hood, on the driver side.
In either location, it will be a 10A fuse. This will solve your light problem.
Old Dec 24, 2005 | 12:28 PM
Imax00's Avatar
thanks ill try it out
leatherneck
Sep 30, 2015 09:16 PM
Junebug1701
Sep 25, 2015 01:54 PM
conansriver
Sep 16, 2015 12:17 PM
jwright36
Sep 8, 2015 11:45 AM
