plz HELP!!
Old Dec 27, 2005 | 01:28 AM
Spliff_Star91's Avatar
plz HELP!!
have a problem wondering if anyone can help plz!
it happened last night
all of a sudden as i pulled off the driveway i heard a (hissing noise) coming from the passenger side around the firewall of my car it happened when the car was cold i do live in alberta canada and was around minus 10 degrees that night. it happened to me again that night and in the morning when the car was cold. it goes away when the car temp heats up.
its a 2000 se 5 spd
plz help with any suggestions
Old Dec 27, 2005 | 06:45 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
can you be more specific.. a sound is a sound but with this info no one will even make a comment.. it could be a lot of stuff.....
Old Dec 27, 2005 | 08:50 AM
Mass_Media's Avatar
Mass_Media™
Exhaust leak?
Old Dec 27, 2005 | 12:06 PM
it only happens when the car is cold
its not liquid involved just gas and it seems that there is a build of gas that needs to be realeased which causes the (hisssing) sounds like a pump being punctured this noise can be heard inside the car and inside the egine bay it sounds likes is coming from the bottom of the ac hose but not sure
i was thinking it could be the pcv valve but i dont want to start changing parts untill im sure
any other suggestions
Old Dec 30, 2005 | 12:11 PM
doc2278's Avatar
Doctor D I presume???
I don't know for sure cause I am not near your car but, It could be the vaccuum lines or like you said something along the the lines of a litterally frozen pcv valve,...... But then again you would have a reduction in the performance of the car if it was frozen. Does the hissing sound get louder as you rev the engine or accelerate ?
I guess the most important question in order to solve this is, does it affect the performance of your car enough that you notice it? Then you will know if you have a real problem. Like I said though I am not near your car so I don't know for sure if that is it at all.
Old Dec 30, 2005 | 01:17 PM
GBAUER's Avatar
Vacuum leak. Mine is doing the same thing. Sounds like I have a turbo when it's cold. It took a while to throw the evap air leak code.
Old Jan 3, 2006 | 06:08 PM
thanks guys i found out that my, high pressure hose for the ac is cracked
this is cause the hissing noise when its idleing
riggy
Aug 6, 2001 07:35 PM
madmax97
Jul 4, 2001 10:10 PM
madmax97
Mar 28, 2001 08:57 PM
tunedup
Mar 9, 2001 08:00 AM
tunedup
Oct 25, 2000 07:31 PM
