ECU reset and advanced timing
Old Dec 27, 2005 | 12:07 PM
durckelg's Avatar
I have my initial timing advanced to 17 degrees, if I do the ECU reset procedure will that clear my advanced timing? I believe I read a while back that it will not, I just want to be sure. I have already tried searching for the answer.
http://forums.maxima.org/showthread....30#post2354330
Old Dec 27, 2005 | 12:20 PM
steven88's Avatar
Need A Light?
no it will NOT reset your timing back to stock....once it is 17 degrees...it will stay 17 degrees whether the ecu is resetted or not...
Old Dec 27, 2005 | 01:23 PM
SoonerFan's Avatar
Cletus
this is correct. you need a scanner to change it
Old Dec 27, 2005 | 08:09 PM
durckelg's Avatar
Thanks for the help.
I did the reset because I have been buring more gas lately. It is probably due to the winter gas formulation, the cold, and my new route to work. The car did feels slighty slower after the reset. I guess that proves the the ECU was not retarding anything.
CorollaULEV
30
Aug 9, 2021 08:11 PM
t6378tp
Aug 24, 2015 07:03 AM
1992maximase30
Aug 5, 2015 09:27 PM
Tanvirkamal
Aug 5, 2015 01:32 AM
