If you got 8” wide rims – come in
Old Dec 27, 2005 | 10:01 PM
DrKlop's Avatar
Driving is the next best thing
I’m getting 17x8 rims with 35mm or 40mm offset and 235/45 tires. According to my calculations both setups are fine for the 5th gen but I’m still a bit scared and would like to get a confirmation from someone else.
Thanks in advance,
Mods, please don’t move it to the wheels/tires forum because I need to get help from the owners of 5th gen only and it is also sort of urgent.
Old Dec 27, 2005 | 10:04 PM
Kevin's Avatar
i had 18x8 Z rims with 245/45 on th rears. did not rub on stock ride height nor on H&R's. I think the offset was 30mm
Old Dec 27, 2005 | 11:27 PM
dansmax2003's Avatar
I have Z wheels. 17x8 on the rear. 30mm offset.
Initially, I had 235/50/17 tires and when car was loaded they were rubbing over bumps/dips etc. Only sometimes but it bothered me.
I put 245/45/17 tires and things are better now. I have not experienced any rubbing or other issues.
Old Dec 27, 2005 | 11:57 PM
AnDyMaN's Avatar
i have 245/40/18 all around with 42 offset... all is good here. 18x8 rims..
Old Dec 28, 2005 | 03:27 AM
Bluesbrekr's Avatar
Doctorate in Detailing
18 x 8 rims 38 offset. 245x40x18 tires. No issues. Could probably go down to 35 offset.
Anethema's Avatar
8" rims
18X8 235/40/18, Progress springs, no problem.
Old Dec 28, 2005 | 05:23 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
i run 17X8 (35mm) with 245-45-17 but only on maxspeed springs and there are no issues.
Old Dec 28, 2005 | 05:28 AM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
18x8 w/ 40mm offset running 245 tires on H-Techs. No rubbing etc....
Old Dec 28, 2005 | 08:11 AM
BLKMAX005SPD's Avatar
i had 9.5 inches in the rear with a 275/30 inch tire and it rubbed alittle bit. nothing really bad. never go below a 8 in wide rim, other wise that would look really f'in stupid on your car.
Old Dec 28, 2005 | 08:44 AM
NISMAX03's Avatar
18x8, 30mm offset, 245/40-18, S-techs, no problems.
Old Dec 28, 2005 | 09:08 AM
03maxima1's Avatar
Everyone seems to have 245-40 instead of 235-40. I thought with 18x8 wheels that 235-40 was a better choice.
Old Dec 28, 2005 | 11:31 AM
claudiusmaximas's Avatar
thats what i thought too?
Old Dec 28, 2005 | 12:24 PM
MAXXXD's Avatar
18x8 1/2
I have 18 x 8 1/2 Hiro's on my car with 245-40-18's and no problems.
Old Dec 28, 2005 | 01:53 PM
icelandmaxima's Avatar
Maxima Fanatic
I have 17x8 Enkei's 35 offset with 225/50/17 (mounted with ~50% tread depth left) on coilovers
Old Dec 28, 2005 | 02:23 PM
Bluesbrekr's Avatar
On the 2k2-2k3's the 245/40 are closer to the OEM rim/tire diameter, therefore minimal speedo error. And it fills the wheel well a bit better IMO.
Old Dec 28, 2005 | 03:13 PM
NISMAX03's Avatar
Exactly. Wheels with a 30mm offset and that size tire will have the tires flush up front and slightly tucked at the rear.
Old Dec 28, 2005 | 04:36 PM
irish44j's Avatar
retired moderator
I have 18x8 with 30mm offset, 235/40/18 tires,
and
17x8 with 35mm offset, 225/50/17 snow tires
and
17x8 with 35mm offset, no tires yet, but will likely be 235/45/17 for track.
no rubbing with the 18x8's 30mm offset though...
Old Dec 28, 2005 | 04:51 PM
MrGone's Avatar
I have 17x8 32mm and 17x8 40mm
Old Dec 28, 2005 | 04:55 PM
Ammi's Avatar
350 Detroit Muscle
35 offset will work just fine
Old Dec 28, 2005 | 05:00 PM
mclee45's Avatar
18X8 with 255/45ZR18 tire.. no problem at all.
Old Dec 28, 2005 | 07:57 PM
dude nice car man!!!!!!!!!!!
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
