Dome/Map lights don't work?
Old Jan 8, 2006 | 06:59 AM
vntperformance's Avatar
I just bought a 03 Maxima SE/6spd, and the seller informed me that he did the LED Mod on the Dome/Map lights, he said they worked fine in the past. But yesterday I noticed they weren't working. I checked the room lamp fuse which seemed fine. Any info from peps that has experienced this? Is there a relay that could be out, and if so where is it and what is it called?
Thanks.
vnt
Old Jan 8, 2006 | 05:18 PM
aussie983's Avatar
Check the fuses under the left hand side of the drivers dashboard?
Old Jan 8, 2006 | 05:33 PM
Progress's Avatar
It's business time.
He said he checked the fuse.
Try opening the LED assembly and see if everything is secure connection wise. However I doubt this is the problem if both the map and the dome are out. Are the courtesy (door) lamps out? If so then I'd say it's a fuse or relay.
Old Jan 9, 2006 | 02:22 AM
aussie983's Avatar
My bad. I must have somehow missed that when reading the post.
Old Jan 9, 2006 | 02:49 AM
The courtesy door lamps are still working, when I pulled the room lamp fuse out from under the fuse panel under the dash the fuse was still good. I'm lost.
vnt
Old Jan 9, 2006 | 04:01 AM
Progress's Avatar
It's business time.
vnt
That rules out the fuse. Check the assemblies and see if all the leads are connected.
Old Jan 9, 2006 | 04:34 AM
Yea, i'll do that...what a PITA just for some damn dome lights.
vnt
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
