Are H&R 5mm spacers hubcentric?
Old Jan 10, 2006 | 12:10 PM
MacAlert's Avatar
http://www.optionsauto.com/prodinfo....mber=HR1065662
Ok, I already have these installed but am wondering are these hubcentric?
I noticed that after having the spacers installed, the steering wheel feels loose at times. I had this same problem once before but that was from a loose tie rod. What can be causing this now? Spacers? If so, I will definately be removing those in a heartbeat.
Old Jan 10, 2006 | 12:53 PM
RA030726's Avatar
I'm nutty for Nissans
no they are not, the original hub is still sticking out slightly.
Old Jan 10, 2006 | 01:35 PM
MacAlert's Avatar
Not hubcentric or not the cause of the problem? Do you think an alignment/wheel balancing will fix this?
Old Jan 10, 2006 | 01:58 PM
shurik's Avatar
Pics. Please post pics is possible. I would love to see the results.
Old Jan 10, 2006 | 02:24 PM
RA030726's Avatar
sorry, i mean they are not hubcentric. they are too thin and do not cover all of the hub, so some original hub is still being used. you shouldnt have a loose feeling with a spacer. sometimes a vibration can be felt.
Old Jan 10, 2006 | 02:33 PM
Penguin215's Avatar
Scroll Down
Old Jan 10, 2006 | 02:49 PM
shurik's Avatar
Awsome, this should be a Stiky. Thanks a lot, great info.
Old Jan 10, 2006 | 07:30 PM
MacAlert's Avatar
Hmm, now I am really stumped. I really want to know whats causing my problems. Its like a slight change in alignment but then its fine the next second. Happens often but started after the spacers....weird. I'm going to try an alignment and wheel balancing, see if that does anything.
Old Jan 10, 2006 | 07:32 PM
MacAlert's Avatar
This is all I have (rear spacers). The fronts didn't really change much, which is why I'm considering removing them.
incubusjohnny
Nov 3, 2015 05:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Maxboy23
Sep 4, 2015 06:04 PM
Maxboy23
Aug 11, 2015 11:59 AM
