Question about installation tein s tech & illumina 2000-2001 maxima
Old Jan 11, 2006 | 07:58 PM
TopSpeedNY's Avatar
Okay i finaly got my shocks now i want to install them tomorrow at the authorized center do i need to cut anything to install them or for the turn **** adjusting please help me guys thanks big time!
TopSpeed
Old Jan 11, 2006 | 08:14 PM
TopSpeedNY's Avatar
Bump Bump!
Old Jan 11, 2006 | 08:24 PM
DrKlop's Avatar
Driving is the next best thing
cut the bumpstops, that's probably it.
Old Jan 11, 2006 | 08:25 PM
TopSpeedNY's Avatar
oh okay thanks bro but for the top **** adjustable and that rubber cover is it still needed ?
Old Jan 16, 2006 | 12:54 AM
TopSpeedNY's Avatar
Update: installed my tein s techs and illuminas and set it to 3 all around with cut bumpstomp i believe it makes some squeeking noises in the front when hiting a small potholes what can cause this please help thank you.
TopSpeed
Old Jan 16, 2006 | 01:04 AM
MaxBoost925's Avatar
Drug Money
TopSpeed
They're new. Wait for them to settle.
Old Jan 16, 2006 | 01:25 AM
TopSpeedNY's Avatar
maxboost925 how many miles to settle should i wait ?
Old Jan 16, 2006 | 01:29 AM
Drug Money
I replaced my OEM strut with a new one. It still makes noise after like a month
I'm doing H-Tech's on Blues soon so i don't really care.
Old Jan 16, 2006 | 07:02 AM
jerome johnson's Avatar
Illumina strut install
I did my Hp blues shock swap out with the Illumina adjustables Saturday. Front only with Eibach Pro kit. Old springs. To my suprise car sits up almost 1" higher. I drove for about 50 miles so far and got allignment done yesterday and it is still about 3/4" higher than with Hp blues. I did notice when installing struts that the Illuminas are alot harder to push down then the HP blues. Definatly got a better ride set on 3. If any one can answer this question . Since cutting bump stops. Won't dirt,water damage struts since dust boots are now open at top from cutting bumps stops?
Old Jan 16, 2006 | 12:27 PM
TopSpeedNY's Avatar
i did the wheel alignment as well right away when i installed the struts but this noise is annoying when you hit a pot the shocks and springs are solid rock tthey look steady when i push down the car it doesnt make noise just when i drive and hit small pot holes it does only the front i am clueless
Old Jan 16, 2006 | 01:23 PM
DrKlop's Avatar
I think you should give it a couple more days. If it won't stop take it to the shop that did the work for you. They should not charge you for that.
Old Jan 19, 2006 | 07:09 PM
TopSpeedNY's Avatar
okay i figured the noise that was comeing it looks like the hood is loose from the front but i have no clue i will post a new thread thanks.
TopSpeedNY's Avatar
Old Jan 19, 2006 | 07:10 PM
TopSpeedNY's Avatar
Thanks i figured out the problem thats causeing the noise it looks like the hood problem i will post a new thread thanks.
TopSpeed
TopSpeedNY's Avatar
TopSpeed
Old Jan 20, 2006 | 01:19 PM
TopSpeedNY's Avatar
TopSpeed
mikekay
Aug 10, 2015 12:52 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
