Just reached 40k in mileage...what maintenance do you suggest?
Old Jan 13, 2006 | 04:10 PM
ressling's Avatar
HOOSIER Daddy?
Couple of notes/problems that i've been noticing:
"Squeaking" noise from front right wheel area
Interesting "musky / mildewish" smell from the interior cabin
Car somewhat leans to the right (alignment i'm sure)
I'm sure I should probably replace the in-cabin microfilter, oil, and some other obvious things. Would you recommend new tires? (still have stock ones on)
Thanks for the help everyone
Old Jan 13, 2006 | 04:17 PM
NmexMAX's Avatar
dot dot dot ...
Well, read the manual and see what it suggets.
If your tire need replacing, replace them seems like a no brainer.
Oil should be changed every 3-5k...so I hope you've done that.
Old Jan 13, 2006 | 05:49 PM
MONTE 01&97 SE's Avatar
For the smell wash or change the in cabin filter that may help.
Old Jan 13, 2006 | 06:09 PM
rule da road's Avatar
first thorough tuneup? If your tires have enough tread on them keep em but an upgrade will be beneficial. I'm cheap so make your own decision. Squeeking reall loud or low. Bearings for loud brakes for low from experience. Theres so much to do too not enough time to list
Old Jan 13, 2006 | 06:15 PM
Jasonb1982's Avatar
Sounds like too many front right tire burnouts.
BURN your crapotenzas before they cause you to knockonwood get in a accident or worse. Get yourself some Falken Ziex 235/45/17s (little wider and lower and speedo reads 61.8 instead of 60mph) or if you have $$ Michelin Pilot Sport A/S.
Old Jan 13, 2006 | 06:30 PM
super6's Avatar
tighten up the nut behind the wheel....
just kidding, if u really want to go crazy, get some speed bleeders and change the brake fluid, thats not in the owners manual but would be good to do.
Old Jan 13, 2006 | 10:38 PM
jdjones4's Avatar
the squeaking could possibly be your serpentine belt...mine needs replacing after 68000 miles...does the sound disappear after about 5 min. of driving?
Old Jan 14, 2006 | 02:30 AM
Jibberish18's Avatar
I'm really **** about maintenance so I'd probably change the cabin filter, transmission fluid (complete flush torque converter included) and filter, PCV valve, Air Filter, Possibly Coolant, Power Steering Fluid. I might leave the Coolant and Power Steering until 50K miles. Oh and alignment and tire rotation......man theirs a bunch of stuff to maintain on a car.
Old Jan 14, 2006 | 05:49 PM
01maxima4u's Avatar
cabin filter/tranny filer and oil/serp. belt.
Old Jan 14, 2006 | 05:57 PM
ressling's Avatar
HOOSIER Daddy?
thanks guys I appreciate the input. I also need to do something about my moonroof -- the da*n drape it offtrack and it's stripping the side of the drape roofing...sheesh.
TKHanson
Nov 24, 2018 01:39 AM
maxinout93
Oct 31, 2015 02:04 AM
Calabar
Oct 5, 2015 09:57 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
