Wiring in o2 simulator.
Old Jan 16, 2006 | 05:21 PM
Derrick2k2SE's Avatar
OK, I've read the how to but am still unsure about which wires to tap into. I am not the greatest with a volt meter and could use some help.
When I test the 4 wires I find two of them to be 12 volts. One of them is around .2 volts and one is ground.
Is the white wire (.2 volts) the sensor signal?
Can I tap into either 12 volt wire for power?
Old Jan 16, 2006 | 06:44 PM
Larrio's Avatar
The Definitive AE Master
white - signal
red - power
black - ground
pink - heater (do NOT cut this wire)
this was on my car, i'm not responsible for mis-installations
Old Jan 16, 2006 | 08:59 PM
Thanks. The wires are different on an 02. I'm figuring the white one is still the signal and either 12 volt will work for power. I hope that's right since I just did it. I'll find out tomorrow when I get the code cleared.
Old Jan 16, 2006 | 09:17 PM
Puppetmaster's Avatar
My understanding is that:
Black: signal
Grey: ground
White (12v): power
White: heated
But let me do a search to double check. Have ya tried looking in the FSM? Its prob in there somewhere as well.
Old Jan 16, 2006 | 09:23 PM
Found a post by sloppymax:
http://forums.maxima.org/showpost.ph...64&postcount=3
And a more detailed post:
http://forums.maxima.org/showpost.ph...7&postcount=13
From this thread:
http://forums.maxima.org/showthread.php?t=372569
Old Jan 17, 2006 | 07:00 AM
Larrio's Avatar
wiring depends on if your tapping into the o2 sensor wires or the engine harness wires prior to the o2 sensor plug
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
