AMB temp button
AMB temp button
Great! My ACC lights are burnt out, so today I took everything apart to take a look. I guess in the process I must have done something to the AMB button, cause now with everything reinstalled, it doesn't work. All the other buttons on the ACC unit work, just not the AMB one.
sonofab1tch.
Any suggestions, the last thing I want to do is to get a new unit for just the AMB, but I would like it back.
sonofab1tch.
I made sure when I put it back in that everything was the exact same, so I thing I must have broken something on the inside. The problem was that I couldn't remove the CB from the face of the ACC unit. I think I might have pulled too hard and loosened a connection or something.
To change the bulbs, you have to remove the acc unit by removing all the trim and unscrewing the unit from the bracket. Open the unit up and look at the back of the CB, the three Blue round things on the bottom or the bulbs, you can twist them out and replace them.
But what did you do to remove the trim?? I dont remeber any screws, and I am 270 miles from my car...
Also do you know the code on the bulb?? so I know what I need to replace them with.
To remove the trim, go here http://carstereohelp.com/stereoremovalNisMax3Str.htm
The harness are a little tough to take out, but it can be done.
Not sure what the codes are on the bulbs, i believe you can wire in a 5mm led with a 560k ohm resistor and that can work. The bulbs otherwise are expensive from a dealer.
Same thing happened to me about a year ago. I took everything apart to replace a bulb and in the process another one went out. I figured that if one of them is old enough to go bad, then all of them could be, and all the movement of the panel just sped up the process. So I bought another bulb, replaced it and haven't had any troubles since.
Fat
Fat
tarun900
19
Dec 20, 2021 06:57 PM
Apr 16, 2020 05:15 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
