front brake conversion
Old Jan 28, 2006 | 01:09 PM
  #81
NOCturnalI30's Avatar
From reading this thread the impression im gettin is that the calipers and rotors from a 6th gen will only fit a 5.5 not a regular 5th gen is that tru???
Old Jan 28, 2006 | 01:51 PM
  #82
Park2670's Avatar
The Ultimate Driving Machine
I just finished the install. It was not that much work except I couldnt figure out the stupid rear pistons. After I got that worked out I started bleeding the lines. I cant get the pedal to get stiff, I have bled and bled and bled until there isnt any air coming thru, but the pedal still drops...... any suggestions?
Oh btw I did new front calipers, then ss lines, pads and rotors front and rear.
Old Jan 28, 2006 | 01:54 PM
  #83
Park2670's Avatar
Are you kidding me??
Old Jan 28, 2006 | 02:59 PM
  #84
Hoooper
lol, he cant read giant yellow letters
Old Jan 28, 2006 | 09:38 PM
  #85
Park2670's Avatar
Anybody wanna help me with my problems?? I have heard to just bleed a little more and check for bubbles. Also have heard that I could have blown the master cylinder. I dont want it to be the second thing...
I have just used sooooo much fluid, I swear there cant be anymore bubbles.
Old Jan 28, 2006 | 11:40 PM
  #86
Hoooper
im sure that its not this, put when i did the clutch on a saturn the whole hydraulic clutch assembly was pre bled...im not sure, but maybe getting air into the system and trying to bleed it wont work because theres air in the master cyl. try bleeding the master cylinder, if that doesnt work try takin it off and bench bleeding it. if not, check for leaks in the lines, otherwise id say you probably blew a master cyl seal...
Old Jan 29, 2006 | 12:02 AM
  #87
Park2670's Avatar
I have been searching quite a bit and I found that I used the wrong procedure. I went RR,LR,RF,LF. I read that its better to go diagonally and to unplug the battery to disable the abs systems. What is the correct way to bleed the master cylinder?
And do you know why you must unplug the ABS? It doesnt really make sense to me.... Thanks for your help
Old Jan 29, 2006 | 12:44 AM
  #88
Hoooper
i think bleeding the master is the same as bleeding the wheels, just a different fitting. on most cars the way you did it is right, i guess our is different. unplugging the ABS doesnt make sense to me either, but whatever makes it work...
Old Jan 29, 2006 | 06:30 AM
  #89
rbrown81's Avatar
But why is teh Rum gone?
Park
When bleeding the brakes you start with the brake furthest from the master cylinder and work inwards from there. I do not know the exact order, however I do know that this process is consistent on most cars.
Old Jan 29, 2006 | 07:36 AM
  #90
Park2670's Avatar
Originally Posted by rbrown81
Park
Thats what I started with and I still have air in there somewhere. After extensive searching I found thats its supposed to go in a diagonal. I think I may have just been moving this air pocket front to back, and then giving up again.
Old Jan 29, 2006 | 08:25 AM
  #91
IWNTMORHP!!'s Avatar
CAN YOU PUT IT ON THE WALL?
anyone got prices on loaded calipers they can discuss, or do I have to call daveB? I am gonna do this as soon as the car gets back from the body shop got some extra insurance money to blow
Old Jan 29, 2006 | 11:15 AM
  #92
Originally Posted by MetaOrbit
Well while we're at it:
looks like you need a bit of air.
Old Jan 29, 2006 | 01:18 PM
  #93
MetaOrbit's Avatar
Got Projectors?
Thanks, you're only the 5th person to point that out on a 3 month old picture.
Old Jan 29, 2006 | 06:29 PM
  #94
i was just bustin your lugnuts. geeze. i am sorry to offend you. i didn't see anyone else in that thread mention it. how has the extra weight from the rotors affected the performance? any noticable change?
Old Jan 29, 2006 | 07:20 PM
  #95
Park2670's Avatar
I got my straight from the dealership. I work for a BMW dealership right across the street and am still wearing my uniform when I go there. They give me wholesale prices, it usually works out pretty nice. The reciept says that list price is 80 a piece for 6th gen front calipers.
Old Jan 29, 2006 | 07:21 PM
  #96
Park2670's Avatar
Oh and Hoooper, I havent done anything to my car today... just let it sit there. It looks like the fluid level has dropped again in the reservoir. I think what happened is that I got a huge pocket of air in the master cylinder. Its slowly getting rid of itself. The pedal doesnt go alllll the way to the floor anymore, just a few inches off it.
Old Jan 29, 2006 | 07:24 PM
  #97
thanks park...may ask you to pick up a set for me appreciate you droppin the 411.
Old Feb 21, 2006 | 02:20 PM
  #98
03MajesticMax's Avatar
Shift_MajesticFemale
Does anyone know the exact part number for the 6th gen calipers?
Cornelia
Old Feb 21, 2006 | 05:13 PM
  #99
Park2670's Avatar
yea the numbers are they are different for left and right.
41001-7Y005
41011-7Y005
Oh and BTW I finally figured out what was wrong with mine, I feel kinda stupid about it. I put them on the wrong sides and the fronts had a GIANT air pocket in them because of this.
Old Feb 21, 2006 | 08:02 PM
  #100
41001-7Y005
41011-7Y005
Thanks... Can you do the rear too??? I am interested in an "all arround" conversion. If so, do you have part numbers for the rears???
Old Feb 21, 2006 | 09:20 PM
  #101
Park2670's Avatar
I have no idea on the rears. I just put new rotors and pads on the back to match the fronts.
Old Feb 23, 2006 | 08:18 AM
  #102
Thanks Park....
Has anyone else done this conversion all arround???
Old Feb 23, 2006 | 09:24 AM
  #103
ICULookN's Avatar
I'm curious also.
Old Feb 23, 2006 | 10:14 AM
  #104
rbrown81's Avatar
Originally Posted by 03MajesticMax
Thanks Park....
I am checking with Matt Blehm currently. Im not certain, but I dont think the size of the 6th gen rear calipers is substantially different, if at all. It may not be worth it.
Old Feb 23, 2006 | 11:36 AM
  #105
MetaOrbit's Avatar
Got Projectors?
I think I read that because of the design of the 6th gen independent rear suspension setup that the rear brakes wouldn't adapt easily to our A33 chassis.
*Note, that's what I "think" I remember reading a LONG while back. Don't take it for fact just yet.
Old Feb 23, 2006 | 01:25 PM
  #106
jimmycapp's Avatar
I have to go check my archived email's, because I am almost possitive I had a conversation with Matt a little while ago and he said the 6th gens don't fit. It may have been about one of his upgrade kits though.
James
Old Feb 23, 2006 | 08:34 PM
  #107
ICULookN's Avatar
I thought I read somewhere that someone did do it.
Old Feb 23, 2006 | 08:42 PM
  #108
STi 2006's Avatar
i have brembo brake system, working fine
Old Feb 23, 2006 | 08:43 PM
  #109
STi 2006's Avatar
i love the rotors man, nice
Old Feb 23, 2006 | 08:46 PM
  #110
Matt93SE's Avatar
STFU n00b!
the rear calipers on the 6th gen are tiny, but the rotors are slightly larger than the 4th and 5th gens..
the big problem is that the parking brakes are completely different between the 4/5 and 6 gen. it's a huge PITA to do the conversion. I have done it with the Z32 brakes and a custom parking brake setup, but the 6th gen stuff won't fit without a bunch more custom work in modifying the wheel hubs and other cool $$$ projects.
Old Feb 23, 2006 | 09:00 PM
  #111
djfrestyl's Avatar
Suspension Yoda
That's great.
Why are you on this forum?
Old Feb 24, 2006 | 05:17 AM
  #112
Does anyone have pics of the setup with 6th gen in front and 5th oem in the rear?? I am afraid that it will look wierd.
-Cam
Matt93SE
May 24, 2019 02:58 PM
AcuraLegend
Sep 22, 2015 04:22 PM
homeyclaus
Sep 3, 2015 06:15 PM
A32goldylocks
Sep 2, 2015 06:39 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
