Quick help, tach signal wire
Old Jan 22, 2006 | 04:45 PM
MaxBoost925's Avatar
Drug Money
WHere is it in the cluster? MetalMaxima and other pros can help me. My interior is in pieces right now, so i need help!
If possible, I'd like a pic with illustrations explaning ground, +12v, and signal.
Old Jan 22, 2006 | 05:14 PM
Drug Money
please! i need help quick!
Old Jan 22, 2006 | 07:19 PM
Puppetmaster's Avatar
Download a 2000 FSM and all your answers will be there. Where to download? Use the search function and find out.
Old Jan 22, 2006 | 07:26 PM
Deckdout2's Avatar
Play with my balls
This information can also be found in the Audio Section.
5th Gen 2001
12volts: green (+) Location: ignition harness
Starter: black/red or (+) Location: ignition harness
black/wht
Second Starter: black/blue (+) Location: ignition harness
Ignition: black/red (+) Location: ignition harness
Accessory: red/yellow (+) Location: ignition harness
Second Accessory: white/blue (+) Location: ignition harness
Power Lock: gray (-) Location: pin 23 at SECU
Power Unlock: brown/yel (-) Location: pin 35 at SECU
Lock Motor: purple Location: pin 15 at SECU
Unlock Motor: white/black Location: pin 13 at SECU
Parking Lights: red/blue (+) Location: driver kick panel
Parking Lights: lt. blue (-) Location: headlight switch
Trunk/Hatch Pin: purple/yellow (-) Location: pin 38 at SECU
Hood Pin: yellow/red (-) Location: pin 27 at SECU
Trunk Release: blue Location: pin 12 at SECU
Factory Alarm Arm: orange/black (-) Location: pin 41 at SECU
Factory Alarm Disarmrange/blue (-) Location: pin 30 at SECU
Tachometer: white/green Location: instrument cluster
Brake Wire: red/green (+) Location: brake switch or drivers kick
Horn Trigger: green/white (-) Location: steering column
Old Jan 22, 2006 | 08:24 PM
maximillien's Avatar
That list only is about 50% correct, I had to find the tach manually underneath the hood. Unplug your fuel injector plug, and look at the wire coming from the harness side, see all the colors of the rest of the injectors. The tach wire is the wire that is different from the rest meaning:
if all the injectors wires has red, then the plug that you want to use is the wire that is not red get it?
If you still confused lemme know. Another way is to use a volt meter. Tap it in the wire you think is the tach. Turn on the car and rev the motor, if the volt jumps up high then that is the wire.
chernandez1278
Sep 16, 2015 01:18 PM
BrandonCause
Sep 14, 2015 10:41 PM
