Rod bearing?
Old Jan 24, 2006 | 10:18 AM
5thgenmaxima's Avatar
Rod bearing?
When my car sits at idle for an extended period of time, I also get the normal tick....
I haven't investigated yet, but it sounds almost like a Rod Knock...Defiently SOUNDS like it's coming from the lower end... Experienced ones here will know what I mean....
Anyway's 00 Max, 59,xxx miles..Plenty of oil...Seem's to be plenty of oil pressure while driving, only does it at idle...
Is this a common problem? Is it unheard of? Or am I just being to dam picky??
Old Jan 24, 2006 | 03:09 PM
KRRZ350's Avatar
I swear our 3.5l has an occasional rod-knock, sounds horrible, you can even hear it under a light load going slow, and if you slowly rev the motor up in nuetral it REALLY sounds like a rod knock, it only does it during certain times though, I'm going to give it some extended idling and see if that gets it to re-occur, because it's not their all the time, and I know for a fact I'm NOT imagining it or being to picky. I would have brought it in long ago except it isn't an everyday thing, and it probably wouldn't do it for the dealer. I need to be able to get it to do it all the time. I'm going to do some 'extended idling' tonight, thanks.
Old Jan 24, 2006 | 03:54 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by KRRZ350
SHIFT____VCTColdStartRattle
Are you sure it's not VTC?
Old Jan 24, 2006 | 05:40 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
Never heard of ANYONE spining a rod bearing in a VQ30, unless ofcourse its been abused and oil hasn't been changed... but then again I never heard of it. Its not like a SR20 that spins rod bearings quite often.
It might be your timing chain tenssioner bad that is causing a rattle. I personally have the rattle when starting the car up. I also have 140K miles on mine with oil changes done exacly every 3K miles or 1 month- in my case, with Mobil 1 Synthetic. My engine looks LIKE new inside, as I had to repleace my oil pan due to a stripped out drain plug- I kinda poked around inside to see how she looks. I ainticipate another 200K out of her with no problems.
Old Jan 24, 2006 | 11:28 PM
Guess I should have worded that differently....I get the normal tick, and also what sounds like a rod knock.....
If spinning a bearing is unheard of, then I'm not to concerned with it...Thanks for the help...
Old Jan 25, 2006 | 04:08 AM
KRRZ350's Avatar
Well when the bearing spins it digs into the crankshaft journal and things usually go downhill very quickly, plus nissan lower-ends are BULLETPROOF! Maybe mine is the vtc, I don't want to hi-jack this thread though, I'm just going to wait it out.
You should buy an oil-pressure gauge or briing it to a trust-worthy shop and have the oil-pressure checked, a compression test might also be useful. Low oil pressure would usually show up first as a valve train tick and could eventually get worse and then the bearings wouldn't get good pressure either, causing a knock.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
