Toyos......
Old Jan 25, 2006 | 04:12 PM
SixxOne's Avatar
Toyos......
I serached around in the tire forum, but couldn't find a definite answer. I want to get a set of proxes 4, but I am worried about rubbing issues since I am riding on progress springs. I was thinking about getting 225/45/18, but I need to know for sure if there will no rubbing. Also, if you think a different side will be more comfortable I am open to other TOYO options (I have a good deal on Toyos).
As of right now I am riding on Kumho ECSTA Supra 225/40/18 in the front and Kumho ECSTA ASX 225/40/18 in the rear. The ride is really rough. Thanks.
Old Jan 25, 2006 | 04:17 PM
djsoniq's Avatar
I'm getting Toyo T1R's this summer, 245/35/18 I think. Shouldn't have any rubbing issues...
Lontar1's Avatar
Puerto Rico-Maxima Lover
I asked the same a few months back and you could go with 235/40/18 and no rubbing........
Old Jan 25, 2006 | 04:36 PM
irish44j's Avatar
retired moderator
235/40/18 is ideal for wheels that are 7.5 or 8" wide. I have that size in the Proxes 4
Old Jan 25, 2006 | 04:57 PM
HotshotVQ35's Avatar
245/40/18 toyo 4s on my 02 slammed on JICs. Zero rubbing rims are 18x8
Old Jan 25, 2006 | 05:25 PM
MAXRB8's Avatar
I also have 245/40/18 Proxes for on my 8.5" rims although I'm on Maxspeed Springs but def no rubbing
Old Jan 25, 2006 | 06:41 PM
SixxOne's Avatar
Why should I get 235/40/18 or 245/40/18 rather than 225/45/18? Someone enlighten me.
BTW, if you didn't see my sig.... I am riding on 6th gen 18's
Old Jan 25, 2006 | 06:53 PM
MAXRB8's Avatar
Because 225/45/18 is not the stock diameter replacement size, the proper size should be 235/40/18 this replaces the stock 225/50/17 or 215/55/16. Any variations affect your speedometer readings etc. Go with what you want I chose to go with 245/40/18 just to gain a little more rubber to ease the harshness while not deviating from stock by too much.
Old Jan 25, 2006 | 06:58 PM
SixxOne's Avatar
I can live with the speedo a little off. Basically is the fatter or taller tire going to be more comfortable.
Old Jan 25, 2006 | 07:32 PM
irish44j's Avatar
retired moderator
why would you want skinny little 225's on a 8" wide rim?? More rubber on the road = better. It has nothing to do with ride quality.
Old Jan 25, 2006 | 07:47 PM
DUKEE's Avatar
toyo t1r 235/40/18 on 7.5x18
Old Jan 25, 2006 | 07:56 PM
MAXRB8's Avatar
For some reason he seems hell bent on the 225's
Old Jan 25, 2006 | 10:12 PM
SixxOne's Avatar
Actually not... I just want to be sure and get some opinions.
Old Jan 30, 2006 | 04:00 PM
Andrew's Avatar
Not to hijack this thread, but I have a quick question...
I have stock 17's on my SE right now, 225/50/17. Could I put on 225/45/17 without any problems? Thanks!
Andrew
Old Jan 30, 2006 | 05:46 PM
no 235/45/17s are better
Andrew
Old Jan 30, 2006 | 06:48 PM
Hoooper
just like pontiac used to say "wider is better". however, since you said you wanted better ride quality which i assume means smoother, the 45 sidewall will be marginally more comfortable, and marginally worse handling.
you COULD do the 225/45 17, but like ^^^ said, 235/45 would be better. smoother ride and better for your speedo accuracy.
Old Feb 2, 2006 | 03:03 PM
SixxOne's Avatar
Will I notice any differece (smoother ride) between 245 and 235?
Stock 6th gens come with 245/45/18
Old Feb 2, 2006 | 03:32 PM
Hoooper
the only difference between the 235 and 245 is tread width. the comfort part will change with the sidewall size ie 30, 45, 50...
Old Feb 2, 2006 | 03:38 PM
SixxOne's Avatar
I thought since there is more tire on the road, then there is more (wider rubber) room to absorb the shock..... or am I just being 'tarded.
Old Feb 2, 2006 | 03:46 PM
Hoooper
its all about the sidewall. a 245 on a 40 sidewall will be more comfortable than a 235 on a 40 sidewall only because the sidewall is still a bit bigger.
