15mm or 20mm wheel spacers for the rears?
Feb 13, 2006 | 02:16 PM
  #41
Quote: ok ive decided to get the H&r 15mm. but this is to MAXRB8.. whats the difference between the HR3065662 and the HR30656621. I kno the HR3065662 has a 14.25mm shoulder on the stud and the HR30656621 has a 12.85. Why did u recommend the HR3065662?
good question, i was going to ask the same thing after seeing the two on optionautos site. btw outmaxxed when you decided on 15mm is it because 20mm pushed out the VR's too far and 15mm is the closest we can come to it being flush?
Feb 13, 2006 | 05:23 PM
  #42
Quote: good question, i was going to ask the same thing after seeing the two on optionautos site. btw outmaxxed when you decided on 15mm is it because 20mm pushed out the VR's too far and 15mm is the closest we can come to it being flush?
yep..
(10 char)
Feb 14, 2006 | 09:24 AM
  #43
Not sure, I believe, you wuld need different wheel nuts for the 12.85 shoulders, but I just went with what H&R lists, but bought from Options for obvious reasons:
http://www.hrsprings.com/site/index.html
Fill the the "year" box etc
Well it seems the Kics are Hubcentric after all, but I'd still go with H&R and replace the studs IMO:
http://forums.maxima.org/showthread.php?t=456317
Feb 14, 2006 | 02:33 PM
  #44
just my luck, i ordered the 15 mm h&r spacers from auto optionsand i got an email saying they were on back order until 3/21. *sigh*
Feb 15, 2006 | 07:49 AM
  #45
March???
Quote: just my luck, i ordered the 15 mm h&r spacers from auto optionsand i got an email saying they were on back order until 3/21. *sigh*
In March 21? I would get my money back, and find a better deal. Well if you're not in a real hurry then it's all good I guess. But I think that's way too long.
Feb 15, 2006 | 09:43 AM
  #46
Quote: In March 21? I would get my money back, and find a better deal. Well if you're not in a real hurry then it's all good I guess. But I think that's way too long.
Unless someone actually has stock which isn't very likely they are probably back ordered from H&R I know they were when I got my first set and no else had them, Options is one of the few sellers that actually carried stock (volume) probably why they sell cheaper than ebay!
Sorry to hear that OutMaxxed, I may just have a set available before that date depends on when my 4th gen sells, long story I won't bore you with the details but I'll keep you in mind and let you know if I do. Basically I have two sets, one new and one on my 4th gen, if I strip my 4th gen back to stock I'll be able to sell the new set as I only need one set for the rears on my 5th gen.
Feb 24, 2006 | 11:35 AM
  #47
to update everyone, options auto ended up haveing a set from a guy who cancled his order..so i got em! Im havin my friend install them as we speak and we(or he) ecountered a bracket problem. The caliper bolt is seized in the bracket and we have to get it replaced. I got a ride home and waiting on the bracket. Its from a 99, it should work right? Ill keep yall updated
Feb 24, 2006 | 04:49 PM
  #48
cool can't wait.
Feb 24, 2006 | 05:21 PM
  #49
In additon to the offset, the rim width is also needed to determine what spacers will fit the best.
Feb 24, 2006 | 07:04 PM
  #50
haha wow didn't know u got it done TODAY?! anyways, looks hot. and it was damn cold out to do it today. post pics.
Feb 24, 2006 | 09:18 PM
  #51
Quote: haha wow didn't know u got it done TODAY?! anyways, looks hot. and it was damn cold out to do it today. post pics.
HELL yeah it was cold ..shiET.... I got tehm on and i was lookin at it after i put them on and notised the right side(while lookin at it from the front of the car) sits in more than my left. I looked at where the mud gaurd to see where it stuck out. My max leans on its left for some dag gome reason. so my driver side rear sits low. I noticed it a couple months ago when i let my friend drive my car and looked at mine from behind. I havent figured out why it sits like that yet, im thinkin the struts? It sat like that before i dropped it on maxspeeds. any one know what it is?
Anyway, ill TRY to get pics tomorrow, Its freaggin COLD up here in New Joisey...
Feb 24, 2006 | 09:45 PM
  #52
today was cold, windy as heck. good job, i wanna see it. and i want your springs when you get your h-techs. im probalby gonna end up getting g35 wheels in the spring.
Sep 25, 2006 | 05:49 PM
  #53
Man, Why doesn't H&R make 10mm spacers? I have the 15's and I get rubbing on the right rear tire during hard cornering.
Sep 25, 2006 | 05:55 PM
  #54
I bet your rear beam isn't centered.
Sep 25, 2006 | 06:26 PM
  #55
Wow this threads back form the dead.
Quote: Man, Why doesn't H&R make 10mm spacers? I have the 15's and I get rubbing on the right rear tire during hard cornering.
They dont make 10mm because they wouldnt be able to make them hubcentric.
Yeah i figured that out a few months ago while reading a thread on the center beam.. actually i think it was u who said it in the thread.
Sep 25, 2006 | 06:28 PM
  #56
They make 5mm spacers that you can double up if you need to. But if you are only rubbing on the right then it is proabably the problem with the uncentered beam.
Sep 25, 2006 | 06:48 PM
  #57
anyone experience any vibration while driving with spacers installed?
Sep 25, 2006 | 07:03 PM
  #58
Sep 25, 2006 | 07:23 PM
  #59
None with the H&R spacers.
Sep 25, 2006 | 08:50 PM
  #60
Anyone have spacers on with 20 x8.5? I think I need to get some for the rears. Do you measure from the rotor to get the length? Thanx
Sep 25, 2006 | 09:22 PM
  #61
Found a pretty good fit with the Eibach Pro spacers. They're only 5mm but worked well for my setup.
Sep 26, 2006 | 05:40 AM
  #62
What's the offset of those wheels?
Sep 26, 2006 | 07:18 AM
  #63
18x8 with a 40mm offset
Jan 26, 2009 | 07:14 PM
  #64
my 02 max is stock. will 20mm spacers be good?
Jan 26, 2009 | 09:31 PM
  #65
Wow this is an old thread. Yes 20mm will be fine. But they will make the rears sit farther out than the fronts. 15mm will make them even.
Feb 11, 2009 | 09:29 PM
  #66
What if you got 5mm for the front and 20mm for the back? Would it sit more flush orr is it not worth it? Save some money and just get 15mm for the back? I'm talking about stock rims on an 03 SE. Anyone have pictures of an 03 with stock rims and spacers? If so, what size did you end up using?
Thank you
Feb 12, 2009 | 09:27 AM
  #67
You could do the 5 and 20 like you said, its been done before and looks good. I was using 15mm spacer on the stock SE wheels but don't have any pics as I just put the rims in my sig back on still with the spacers.
