Climate Control Lights Out
Old Feb 1, 2006 | 08:09 PM
RoNx777's Avatar
2K Max, on the center console, the backlight that emites from the buttons of climate control are blacked out but the digital temp. display still works, button for the audio section is fine.
Do they run on diff. fuses if so does anyone know which one and where is it located for the climate section???
~Ron
Old Feb 1, 2006 | 08:49 PM
PandaXpress's Avatar
not fuses..just the bulb burned out...get new ones...my recommendation..LEDS with resistors. IF it was a fuse, the whole thing wouldnt work, let alone have illumination.
Old Feb 2, 2006 | 12:32 PM
Biggs_02's Avatar
yeah you gotta open it up, on my 2k2 manual control, and pop open the back, then you can change the bulbs, just solder some leds on there and i'll last forever.
Old Feb 2, 2006 | 01:10 PM
nyautostyle's Avatar
its either that or maybe you tried taking it apart? I've done that before with my maxima. just had to fix the bulb in the place for it to work again. but if your gonna change it, i highly recommend the LED lights.
Old Feb 2, 2006 | 01:30 PM
RoNx777's Avatar
no i never taken it apart before, so basically i gotta rip out the center console ?
Old Feb 2, 2006 | 02:22 PM
GBAUER's Avatar
I had mine go out for a while. I just hit the side of the counsel and they came back on. No problems since....
Old Feb 2, 2006 | 02:28 PM
upstatemax's Avatar
I just replaced mine a few weeks ago, really easy and I did not feel like playing with LED's and resistors so I just went ot the dealer and got new factory bulbs. They were about $3.50 each.
upstatemax's Avatar
Where in NYC are you, I might be able to help.
Old Feb 2, 2006 | 04:14 PM
Biggs_02's Avatar
yeah you gotta rip the center console out. there are 3 bulbs in the back of mine and 1 was burned out for sure and 1 kept on turning on when it wants too i had to hit it a couple of times and now it's fine...i opened it up went in peel out the condom thingy over the bulb and now it's brighter but orangeish..i guess if you like orange you can do that but i'm gonna switch to blue led soon
Old Feb 2, 2006 | 04:21 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
I don't recommend this, the light distrinution is very spotty.
Old Feb 2, 2006 | 07:31 PM
AceofSpds's Avatar
wat
Sometimes mine dont come on in the early mornings, all i do is push on the edge of it and they light right back up.
Old Feb 2, 2006 | 08:31 PM
DUKEE's Avatar
What bulbs or leds do poeple suggest switching them with? Can you put polarg's 194 behind there? I also have a my drivers side heater switch bulb that burnt out. However, my drivers side heater seat switch bulb is fine!
Old Feb 4, 2006 | 05:40 PM
RoNx777's Avatar
I'm in sunset park brooklyn
Does anyone have a "How-To" on this, i never taken out the console before, dont knw where to start
Thx
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
asianstyle
Aug 24, 2015 08:29 PM
