Noise from belt
Old Feb 5, 2006 | 11:48 AM
EastSideMaxima's Avatar
A swift Bimmer driver
Noise from belt
I'm hearing this noise from the belt when the engine is running... I doesnt change even after driving for an hour...
what could it be? I replaced the belt a year ago...
It's an '02 Max with 40,500 on the clock.....
Please help me out guys...
Manoj
Old Feb 5, 2006 | 11:50 AM
BRINKLEY's Avatar
Manoj
have you tried spraying it with belt dressing? I use STP from autozone.
Old Feb 5, 2006 | 12:35 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
it could be the cold weather... use some belt dressing a few times if it comes back.. try adjusting it again....
Old Feb 5, 2006 | 06:36 PM
Hmm... Belt dressing? I've never heard of it, but I will get one tomorrow!
Thanks guys...
It probably just needs lubrication with this right?
Old Feb 5, 2006 | 06:48 PM
BRINKLEY's Avatar
belt dressing comes in a can, and you spray it on. And yes, it is just a lubricator.... hope this works for you.
Old Feb 5, 2006 | 08:25 PM
TPenguin's Avatar
Got Penguin?
If you belt is squeaky Might I suggest that before you use belt dressing that you inspect the current belt and belt tensioner. Could be a loose tensioner that needs tightening OR could be a belt that is frayed and needs replacing. Either way belt dressing is a temp fix ONLY. It could also be a loose AC Compressor/Alternator. Personally get your self a belt $15.98 from Kragen...
Old Feb 7, 2006 | 07:04 AM
dank104's Avatar
I agree...my belt was sqealing before and I re-adjusted the belt tension (tightened it) and it went away. Same thing happened with my friends car and we tightened it and the sqealing was gone.
Old Feb 7, 2006 | 07:29 AM
kcowden's Avatar
I just added new belts recently and after a while they loosened up a bit and made a little noise. A quick tightening and it was all taken care of.
Old Feb 7, 2006 | 04:17 PM
guys.. the noise went away before I did anything.. I will be monitoring this closely... also..how would i go about tightening it... Should I have a technician do it?
Old Feb 7, 2006 | 04:19 PM
zgrm100's Avatar
Guys my car has the same squeeky problem! How do I tighten the belt? And which one do I tighten? Also how do I know if anything is loose? Im a newbie when it comes to this as I just changed my own oil yesterday so I wo uld like to be able to fix something like this. Having said that, I have 67,000 miles on the car and had it from new and I did not change any belts yet. Should I take it to the dealer to change the belts?
Old Feb 7, 2006 | 08:53 PM
TPenguin's Avatar
Got Penguin?
To the left of the engine you will see a bolt I believe its a 14mm but i could be wrong.. turn the bolt counter-clock wise and it will tighten it up... The bolt is directly above the belts so you really cant miss it..
Old Feb 8, 2006 | 09:18 AM
dank104's Avatar
If you've never changed your belts it might be squeeking b/c the belts are old and cracked. It makes that noise either when it's too loose, or if the belts need to be replaced.
Old Feb 8, 2006 | 10:38 AM
kcowden's Avatar
You first need to loosen the pully bolt that is right beneath the adjusting bolt next to the engine. That pully bolt locks the pully in place so just turning that bolt next to the engine does nothing. That will tighten/loosent he AC belt.
In order to tighten the power steering belt you'll need to take off the right front tire, remove the crank pully cover and get in from there. You'll need a swivel adapter for your socket wrench. I think it's a 12mm bolt that you adjust. There is also a locking bolt right up from the adjusting bolt. If you think you have the ability to take this on you'll see what I'm talking about.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
