How to AIM headlights on '01
Old Feb 6, 2006 | 02:48 PM
zgrm100's Avatar
Hi guys. I did a search but found a lot of iirelevant posts. I need some help... I got some aftermarket HIDs that I want to aim. Can any1 help me out with some pics even on where the adjustments are? I see some long screw coming out of thew housing, is that the adjustment? Thanks.
Old Feb 6, 2006 | 02:52 PM
merovi's Avatar
its a plastic hex nut. turning 1 way or the other will move the beam up or down. Pretty straight forward.
Old Feb 6, 2006 | 03:03 PM
zgrm100's Avatar
where is it located? And which way is up or down? thanks
Old Feb 6, 2006 | 04:08 PM
MaxBoost925's Avatar
Drug Money
I did the AE mod yesterday, I believe its on the headlight itself.
Old Feb 7, 2006 | 07:11 AM
Jasovanni's Avatar
Right, I have the ebay angel eye projectors on mine (on it when I bought it) beam pattern is no good, but I'd like to stop blinding passing planes with it, is the procedure the same? I took a good look at the housing and initially have found no way to adjust. Anybody have these/have adjusted?
Thanks!
J
Old Feb 7, 2006 | 12:45 PM
zgrm100's Avatar
is it that long nut that stick out?
Old Feb 7, 2006 | 01:06 PM
resurrectedmax's Avatar
enthuzed.........
it may be covered by a rubber circle. i'm guessing.
Old Feb 7, 2006 | 01:42 PM
Maximized2000's Avatar
To adjust the OEM headlights isn't it the plastic stem (plastic hex) that is sticking out with the white top? Sorry for the blurry picture.
Old Feb 7, 2006 | 02:09 PM
Jasovanni's Avatar
Ah ha! rubber circle! I'll check when I get home, I'll post tomorrow how it went with the Ebay Projectors, if I don't get hit by a blinded plane in the process that is.....
J
Old Feb 8, 2006 | 08:33 AM
Maxipad20's Avatar
Do you just turn the **** to adjust it then?! Thanks!
Old Feb 8, 2006 | 09:10 AM
Jasovanni's Avatar
Ok, on the ebay headlights, behind your low beams there is a bolt, you can turn it with either a phillips head or an 8mm wrench. Clockwise aims the lights down. If you are looking at the back of the projector housing, the bolt is towards the bottom, and on the side nearest the grill.
Hope this helps someone besides me.....
J
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
