Blinker bugging out
Old Feb 15, 2006 | 09:04 AM
jrklar's Avatar
Blinker bugging out
My driver side blinker light (on the dash display) started flashing much faster than usual the other day. I checked my lights and the driver side turn signal/marker light is out. I expect it's pretty easy to replace, but just wondering...anything else I should worry about with this? Should just need a new bulb, right? Was surprised that the dash display light changed it's blinking speed based on the light going out.
Old Feb 15, 2006 | 09:07 AM
bigfatty's Avatar
Booyah grandma.... BOOYAH
Perfectly normal, replace the bulb and it will go away. Dont worry its stupid easy to replace, you will be fine.
Fat
NYPD-Arnold's Avatar
Z
That's what most modern cars do. They blink fast if a light is blown. Just go and change the bulb and that's it.
Old Feb 15, 2006 | 09:27 AM
jrklar's Avatar
thanks for your help!
Old Feb 15, 2006 | 09:45 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
a new bulb
Old Feb 15, 2006 | 10:02 AM
Barc's Avatar
The dashboard light blinks the same speed as the lights outside the car; they are hooked to the same circuit in a round about fashion. Since the relay is "expecting" a higher load than encountered, the rate at which it cycles is faster than normal. It won't hurt the car unless you plan on leaving the light out for a long period of time as the relay has a certain number of times it can blink before eventually crapping out. Granted, this number equates to a time that is usually longer than most folks own the car (since its some insanly high number of cycles) but they can and do go out.
Short answer, you should be fine unless you left your signal on for, oh, I don't know, a few days!
Old Feb 15, 2006 | 10:32 AM
AcerX's Avatar
I think my relay is screwed up. Cause my left blinker still works but the indicator is faster than the right. I don't worry about it though cause when I use to have the old (and I mean OLD) Volvo at first I had to use HAND signals!!! Talk about annoying.
Old Feb 15, 2006 | 10:41 AM
JBFortes18's Avatar
Easy Fix...just get that bulb and your good.
Old Feb 15, 2006 | 10:48 AM
Progress's Avatar
It's business time.
Yep, it's an easy fix. Make sure to refill, maybe even flush, your blinker fluid while you're at it.
Old Feb 15, 2006 | 11:19 AM
NismoMax80's Avatar
SuPeRmOd
When did you last change the fluid?
Old Feb 15, 2006 | 11:25 AM
Progress's Avatar
It's business time.
I don't know about you guys, but I have an extra bottle in my trunk at all times. My blinkers burn through that fast! I do have nearly 90k so it's no surprise. Plus I upgraded my module with a super-turbocharged, advanced timing and compression ratio, VIAS super great thing. I'm happy with it. People always know which way I'm turning even if I give them the ol' switcheroo.
Old Feb 15, 2006 | 12:30 PM
Le1717y's Avatar
LOL blinker fluid is awesome!
Old Feb 15, 2006 | 01:01 PM
Mass_Media's Avatar
Mass_Media™
You guys ever use prestone blinker fluid? When ever i put it in my blinkers blink faster I don't like it so i just stick with OEM. What do you guys run? Ever think about getting a s4950 turbo for the blinker? Just talking here let me kno
Old Feb 15, 2006 | 01:28 PM
Barc's Avatar
I stick with MoDil D0 1 Fool Sinthytic brand only. Its hard to find but it seems to do the trick. PreStoned always made mine blink slower... and made them do weird things like search for Doritos or Twinkies or something and watch Scooby Doo reruns. And then, I always had to add water and Advil the next morning...
Old Feb 15, 2006 | 01:39 PM
TXT-1's Avatar
Oh crap, I haven't changed the blinker fluid since I've owned car. Is it easy to do?
Old Feb 15, 2006 | 01:44 PM
Lontar1's Avatar
Here you go if you need to buy the blinker fluid.
http://kalecoauto.com/index.php?main...&products_id=6
Old Feb 15, 2006 | 01:50 PM
Barc's Avatar
You may as well set fire to the car... its crap now! And sue the dealer for not asking you to do it when you had your muffler bearings replaced... you have had them at least checked haven't you!?
Old Feb 15, 2006 | 01:53 PM
Barc's Avatar
edit...
BTW, this site is great! I didn't even realize I could upgrade to cross-drilled brake lines!
Thanks for that link!
Old Feb 15, 2006 | 02:07 PM
vinny's Avatar
blinker fluid, i know absoloutley nothing about this, what is this all about, does somebody have a link explaing how the fluid works and how and why it needs to be replaced. all the cars i have owned i have never heard of blinker fluid.
Old Feb 15, 2006 | 03:06 PM
Lontar1's Avatar
Only mechanics with years of experience can perform this ... you can loose the muffler, tranny and even the engine if you do it wrong....
Old Feb 15, 2006 | 03:52 PM
TXT-1's Avatar
Just take it to your nearest Nissan dealership. They'll take care of that, your muffler bearings and your flux capacitator. Make sure you don't pay more than $800 or you are getting screwed. Good luck sir.
Old Feb 15, 2006 | 05:45 PM
jrklar's Avatar
thanks for all of the input... i guess i didn't the proper homework before changing the bulb. i went and changed the side marker light, only to find out that it is working fine. it's actually the front turn signal inside the headlight housing itself, on the driver's side. it still blinks, but it's much more dim than the passenger's side. odd.. cause i would have thought it would either work or it wouldn't. should i just try replacing this bulb? thanks again
Old Feb 15, 2006 | 06:35 PM
vinny's Avatar
hey lontar, TXT1,, massmedia, progress, nismomax, le1717y, and barc the joke is on all of you, blinker fluid their is no such thing for everybody who reads this post. one more thing
Old Feb 15, 2006 | 06:50 PM
TXT-1's Avatar
Yea, the jokes on us....
Old Feb 15, 2006 | 06:58 PM
Barc's Avatar
You're KIDDING!?! You mean I paid $1,956.22 for nothing!? The dealership told me my slotted rotors had eaten through the housing for my blinker fluid, thus pouring it (its highly corrosive!) onto the main (and most of the secondary) muffler input shaft and basically shot my muffler bearings, both transmissions, and not one, but all three MAFs! Now I feel so bad.
Oh, back to the question; the side marker light does not blink (from the factory although there are those who have modified this). The bulb is, as you have discovered, next to the headlight and under the city light. Very easy to replace in the grand scheme of things... much easier than replacing, say, your oil or tranny fluid and about as hard as replacing the air filter...
Old Feb 17, 2006 | 07:26 AM
NismoMax80's Avatar
SuPeRmOd
JoshG
Sep 5, 2015 10:10 PM
MacGyver
Dec 30, 2000 10:38 AM
2000MaximaSE
18
Sep 27, 2000 10:42 PM
MOBOY
Sep 26, 2000 09:10 PM
