how to prevent bolts from snapping off!?
Old Feb 20, 2006 | 06:05 AM
bigfy39's Avatar
i was putting on my catback and in order to connect the b-pipe to the cat i had to take the heat shield on the cat off, well, i put some pb spray on it and used a wrench and the bolt just frickin came off, i didnt touch the other 3 i dont wanna f them up, guys got any suggestions how i can safely takem off? thanks
Old Feb 20, 2006 | 06:28 AM
GBAUER's Avatar
I've had that problem with about 50% of the bolts on my max as well. I really wonder if it's me or just shoddy materials.
Old Feb 20, 2006 | 07:32 AM
JaKillz2's Avatar
Just had that happen actually, the head just popped off with like 20 lbs. The way I have dealt with this is to buy a reverse bit, drill a small hole into the actually screw body, and drill (it would be counterclockwise) into that whole with the anti bit which then turns it out as it tightens
Old Feb 20, 2006 | 08:05 AM
miksen's Avatar
FU, FU, FU, You're Cool..
I have always had good luck using a torch to heat them up first...not too hot just good and warm to let them break free
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
