auto es motor mounts
Old Feb 20, 2006 | 11:37 PM
k2max_driver's Avatar
went on to the energy susp. website looking for motor mounts inserts for my 5.5 auto. found them but they are only for 6-speeds. does anyone make inserts or complete mounts for our auto's? c'mon we need em' too!!
Old Feb 21, 2006 | 03:08 PM
FASSTER's Avatar
Bump, I second that question. ?
Old Feb 21, 2006 | 03:14 PM
boondoxmax's Avatar
Not really needed for autos. My 02 autos engine mounts where just fine because auto don't have as much engine movement as manuals. Not the 6 speed is another story. My engine moves way to much and the car bucks aroung like mad. I haven't changed to energy mount because I like the smoothness of the engine and with stiffer mounts you get more NHV.
Old Feb 21, 2006 | 08:43 PM
well i knew a 6-speed max owner would say that. but honestly we only make about 10 ft. lbs. less than you guys. i can guarantee you that our motors move around just as much as yours. we need these mounts c'mon i know there are some auto max's out there with upgraded mounts. anybody?
Old Feb 22, 2006 | 06:39 AM
boondoxmax's Avatar
Your mounts don't move around as much. I've owned both and its not even close. The autos also have different motor mounts then the 6sp. The autos have electronic controlled mounts and the 6sp dont. Plus the autos don't really have the wheel hop issues the manuals do......
Old Feb 22, 2006 | 08:09 AM
az02se's Avatar
Out of Order . . .
I know I wouldn't mind some better mounts. My car has all kinds of wheel hop off the line.
Old Feb 22, 2006 | 08:22 AM
Stardust's Avatar
F---ing Kangaroos
WOW! talk out your a$$ much? I have also owned both and they are VERY close.
Old Feb 22, 2006 | 11:58 AM
boondoxmax's Avatar
Are you insane. I could let off the gas in my auto and never get the feeling my engine was moving. The 6sp engine mounts suck and are different from the auto. The autos engine mounts are larger because they are electronic controlled while the 6 speeds are not. That's the reason ES doesnt make engine mounts for the autos. And if you can't tell the difference in feel between the way the engine moves on 6sp vs autos then something is wrong with you or you've never driven a 6speed. That's why so many people who really owned a 6sp complain about how difficult it is to drive the car smoothly. To much bucking due to the crappy engine mounts........CAR IN YOUR SIGGY SAY 2000 SE-HUH
With that comment I highly doubt you've every owned both
By the way here is a pic of both my 5.5
Old Feb 22, 2006 | 12:27 PM
Larrio's Avatar
The Definitive AE Master
I'm surprised you can "feel" the engine moving while inside the car. Unless you are driving without a hood there is no way to judge how much one moves more than another. I've seen both auto and manual 4th and 5th gens on a dyno and the motor moves considerably, regardless of transmission type
btw, the motor mounts are the same between 95-03 manual maximas and is not relevent to only 6spd maximas.
EDIT: to answer the original question, the auto mounts are larger because they are electronically controlled and hence there is no bushing insert for it.
Old Feb 22, 2006 | 12:42 PM
NewLoveI30's Avatar
I've always wondered what exactly is "electronicaly controled" in the auto motor mounts? Is there a fluid inside that changes characteristics when a current is introduced?
Old Feb 22, 2006 | 12:45 PM
boondoxmax's Avatar
Maybe I should refaze (sp) my answer. You feel the car buck around more with the 6sp. If I remember the all the mounts on the auto are liquid filled while the 6 speed has one mount that isn't. As a whole the auto feels different from the 6sp. The auto rides firmer due to the weight and the stiffer front springs. When I brought my 6sp I didn't expect it to feel different from my auto but it does.
Old Feb 22, 2006 | 02:46 PM
Larrio's Avatar
The bucking (IMO) is more of a gearing issue. 1st gear in a manual maxima is pretty short and we have a infamous bucking issue when letting off in 1st gear. The auto negates this through a taller 1st gear and the electronic stiffener.
The engine moves around too much in general, regardless of transmission type.
Old Feb 22, 2006 | 02:52 PM
boondoxmax's Avatar
Like they say you learn something new everyday. Thanks, that makes alot of sense. Things on this board would be so much easier if people just explained things without flaming you. THANKS....
Old Feb 22, 2006 | 07:47 PM
all of this was pointless, i still have yet to find an answer. great job guys
Old Feb 22, 2006 | 08:01 PM
Larrio's Avatar
post #9 .......... cliff notes: no one makes it for autos. If you want, change out for manual motor mounts and buy inserts
Old Feb 22, 2006 | 08:41 PM
screw it i've got bigger problems. ill just throw on an engine torque damper or figure out something.
Old Mar 9, 2006 | 10:38 AM
BUSi87's Avatar
Okay so yea wee can i get engine mounts.... my rear one is busted and well my left one iss feeling loose.... i luv my 6spd though i owned both auto and manual max's and well its a pretty big difference...
-ENJOY THE VQ EXPERIENCE-
AaronL
Sep 23, 2015 03:34 PM
vball_max
Sep 17, 2015 10:01 AM
QueensMAX
Sep 15, 2015 04:14 AM
