Brake nightmare
Old Feb 22, 2006 | 02:31 PM
Gapp's Avatar
Brake nightmare
HELP! Every time I hit the breaks, they squeak like a *****! I've replaced the pads with good ones to no avail. It's torture to drive like this! I've scoured the forum for answers but haven't found anything. Any ideas?
Old Feb 22, 2006 | 02:33 PM
spdfreak's Avatar
Are your rotors warped?
Old Feb 22, 2006 | 02:35 PM
Gapp's Avatar
Don't think so. There's no vibration when I brake
Old Feb 22, 2006 | 02:38 PM
5thgenmaxima's Avatar
Are they glazed? (shiny)
Old Feb 22, 2006 | 02:41 PM
Gapp's Avatar
Yes, and not completely smooth. (tiny grooves, not deep)
Old Feb 22, 2006 | 02:43 PM
Get your rotors turned and when you put your calipers back on make sure to use grease on the sliding bolts...Should fix your problem.
Old Feb 22, 2006 | 02:58 PM
Gapp's Avatar
How much does this typically cost?
Old Feb 22, 2006 | 03:02 PM
spdfreak's Avatar
Go to your local brake shop, and let them cut your rotors,,,,,,,,,,,, I woudn't think that it costs more than new rotors!
Old Feb 22, 2006 | 03:04 PM
Larrio's Avatar
The Definitive AE Master
new brake hardware and anti-squeel grease from autozone/walmart/kragen/etc
Old Feb 22, 2006 | 03:07 PM
I think o'reillys does it for around $10 a rotor or something like that..if you have one locally.....
Or call just about any backyard mechanic..If business is slow and they have a brake lathe they may turn them for $50 for all 4.
Old Feb 22, 2006 | 03:30 PM
Gapp's Avatar
I'm going to have it done asap. Thanks for the advice!!!
Old Feb 22, 2006 | 05:59 PM
Gapp's Avatar
Is it necessary to replace the pads again after the rotors are turned?
Old Feb 23, 2006 | 06:21 AM
Gapp's Avatar
Check this out: I had to make a panic stop yesterday in traffic and afterwards, my brakes didn't squeak at all! WTF??? Maybe I burned the coating of sh** off the rotors? Oh well, I'm gonna get the rotors turned anyways...
Old Feb 23, 2006 | 07:18 AM
Barc's Avatar
Did you put anti-squeek grease on when you did the pads? What sort of pads do you have (ceramic pads love to squeek!)? Turning the rotors might help but it may be something as simple as a $1 packet of grease or it might be the pads themselves.
Old Feb 23, 2006 | 07:33 AM
SEmy2K2go's Avatar
Go BUCKS!!!
What are "good ones" in terms of pads? Which did you install?
Old Feb 23, 2006 | 07:41 AM
Gapp's Avatar
I didn't put the grease on. Also, the pads I used were the expensive ceramics at Oh oh oh O'Reillys. Can't recall the brand...
Old Feb 23, 2006 | 11:15 AM
whazzzzuup's Avatar
Thermoquiets?
Old Feb 24, 2006 | 06:27 AM
Gapp's Avatar
That sounds right. I've got a renewed love for the max after that panic stop! Krazeeeeeee!!
Old Feb 24, 2006 | 11:02 AM
elix's Avatar
I'd think you'd want to hold off on getting them turned now. Reducing the mass of your rotors makes them heat up faster. If you've gotten rid of the squeal, my 2 cents would wait to see how things go for a few weeks.
Old Feb 24, 2006 | 11:24 AM
Gapp's Avatar
That's sounds good, especially since my wife took my debit card away again!!
NARF!!!!
Old Feb 24, 2006 | 12:25 PM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
