Oil Leak, Help!!!
Old Feb 27, 2006 | 08:12 AM
mcfalcons15's Avatar
Oil Leak, Help!!!
Just got back from the Dealership for my 75,000 mile checkup, and they told me that I have an oil leak, and that the oil pan needs to be replaced. Is there anywhere I could get this done cheaper than the stealership. Where is a good place that I could buy the parts needed from and take it to get replaced. Any help appreciated. Thanks.
Old Feb 28, 2006 | 06:36 PM
DAP's Avatar
DAP
The oil pan on our cars our small and from the looks, very asy to work on. I've replaced gaskets on front drive 4 cylinders and they are a pain since you always have to remove an exhaust component. If you mechanical you can do it yourself. If I remember, I think one bolt may be difficult but it should not be a problem with the proper tools.
You can lightly tighten the bolts on the oil pan. Most likey they have loosened themselves a little causing a small leak. Be careful not to overtighten or you will really be screwed.
If you decide to take it somewhere, make sure you wait till you need an oil change.
Old Feb 28, 2006 | 08:34 PM
P. Samson's Avatar
Did you see any oil under your parked car any time prior to this? Is the whole bottom of the engine wet with oil? There are two oil pans....the Al alloy one (upper) that is bolted to the block and the steel lower one. Oil from higher up on the engine sometimes leaks (or gets spilt) and it runs/drips down to and capillaries around the oil pan flange(s). I would like to see you get a second opinion.
Old Mar 1, 2006 | 03:26 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
buy the gasket and do it yourself. really easy to do.
Old Mar 25, 2006 | 01:12 PM
MSchumacher's Avatar
yeah he's right....u could do ii yourself and save $$
Old Mar 25, 2006 | 02:03 PM
steven88's Avatar
Need A Light?
Dropping the pan and replacing the gasket is not too hard...just kind of messy..
MaxBoost925's Avatar
Drug Money
Drain oil, take out filter, wait for it to drip, take off pan, replace gasket, reverse
Old Mar 25, 2006 | 05:00 PM
crosbyct's Avatar
You can get the parts from a dealer. Call around because prices vary.
Old Mar 25, 2006 | 06:13 PM
lowincash's Avatar
No More Maxipad
i had oil leak at 88k cuz i noticed some oil under the car and is all wet/oily underneath =/ i'm stupid i paid $176 for a shop to put new gasket and oil pan in for me i'm those kind of people that gets nervous when something abnormal happens to the car and i'll pay whatevers to get it fixed
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
