1999 rear stabilizer bar on 2000-2003 car?
Old Mar 4, 2006 | 07:10 PM
mwbres's Avatar
Does anyone know if a 1999 RSB (Addco) will fit on a Gen 5 car (well actually on my 2004 I35)? Thanks.
Old Mar 4, 2006 | 08:02 PM
NisMoN00B's Avatar
+Cru OG
common sense please.
Old Mar 4, 2006 | 08:14 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
will a size 28 pants...fits a 350 pounds man????
Old Mar 4, 2006 | 08:15 PM
SR20DEN's Avatar
VQ Wizard
Yes it fits.
Old Mar 4, 2006 | 09:21 PM
LA02MAX's Avatar
huh? the RSBs are the same for the 95-2003 maximas...since the 2004 i35 is the same as the 5th gen maxima, it will fit....i think you used the wrong analogy there..
Old Mar 4, 2006 | 10:06 PM
Puppetmaster's Avatar
The RSB will fit 95-03, as already posted...
Old Mar 4, 2006 | 10:09 PM
Deckdout2's Avatar
Play with my balls
Haydn, can I get your rsb for my dad now?
Old Mar 4, 2006 | 10:41 PM
Haydn posted in this thread? Are you drunk?
Old Mar 4, 2006 | 10:46 PM
Deckdout2's Avatar
Play with my balls
Not at all, but I know he will come in here eventually.
We weren't sure if it fit or not, and didn't really go any further to find out. See random threads still do help me.
Old Mar 5, 2006 | 08:08 AM
misiek's Avatar
muscle weighs more than fat...
Old Mar 5, 2006 | 04:40 PM
mwbres's Avatar
Thanks for the answers.
Re the "common sense please" comment, does that mean I should have known it would fit.....or not fit?
Old Mar 5, 2006 | 04:43 PM
GigEmAgs07's Avatar
I'm a rook and it won't let me do new threads yet. Is installing a front strut bar on a 2k SE as simple as removing the 3 screw things on top of each tower, puttin the bar on it, and tightening the screws over it? Sorry to hijack the thread...
Old Mar 5, 2006 | 07:43 PM
That's all you have to do, but don't over-torque any of those 6 nuts when you replace them. Make sure also that the strut bar has enough clearance over the intake manifold, if it doesn't, just add some washers below the strut bar bracket to increase the clearance.
Old Mar 5, 2006 | 08:01 PM
GigEmAgs07's Avatar
is it worth puttin on the fsb if everything else is stock? I don't have a rear bar or anything like that. Just thinkin ahead of a way to use a paycheck come summertime maybe.
Old Mar 5, 2006 | 08:05 PM
misiek's Avatar
yeah its a good mod... makes the front stiff on corners
good start to get out of stock
Old Mar 5, 2006 | 08:20 PM
knight_yyz's Avatar
Toolie
Will the FSB really work if up on washers? I just installed the stillen on my 03 and there is a stupid little bracket that is welded to the metal which used to hold part of the stock air box assy. It actually interferes with the ring on the strut bar and doesn't sit flat. I thought of installing washers underneath but wasn't sure if the FSTB would have the same effect. BTY shame on stillen for not mentioning that the bracket would have to be ground away to fit properly...
Old Mar 5, 2006 | 08:22 PM
I've never heard of anyone having to grind anything to fit a FSTB... I've had an eBay FSTB and an Otto (Stillen knock-off) and have had no such issues... any pictures?
Lakersallday24
Jun 16, 2019 01:35 AM
Huttig2009
Sep 25, 2015 03:31 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
laparka66
Aug 6, 2015 09:36 AM
