Direct HIT??
Old Mar 17, 2006 | 04:00 PM
max929's Avatar
Direct HIT??
Anybody know anything about these, do they really work or is it yet another scam.
http://www.off-road.com/products/rev...hits/hits.html
Old Mar 17, 2006 | 04:03 PM
callkiss's Avatar
Never heard of it.
Old Mar 17, 2006 | 04:12 PM
5thgenmaxima's Avatar
I didn't read the whole thing but.
1). We have a COP (coil over plug) ignition system. There is no possible way to allow for this extra clearance.
2.)
Originally Posted by Reviewer's notebook
faster air/fuel burn times, and very stable operation at very advanced timings.
This in itself is contradicting itself. You set your gap to go with your set-up or timing.
The larger the gap the longer the burn duration and colder the spark. Also allows for advanced timing (longer burn time so it burns up in about the time or right after TDC)
The shorter the gap the hotter the spark and the less burn time. Also less timing is needed.
3.)Your primary ignition system sends out AROUND 40,000 volts regaurdless of what your secondary ignition system consists of.
Alot of systems have a "box" that goes to power from their ignition system that actually increases the voltage going to the plugs. Those are a better bet. Unfortunately it's hard to create that kind of set-up of COP designs.
Sounds like a waste of money to me.
Someone else may know better though.
Old Mar 17, 2006 | 04:13 PM
GBAUER's Avatar
I call scam. No reason. Just looks suspicious. I'll think about it more and get back to you why it's a scam.
Old Mar 17, 2006 | 04:32 PM
ChromeSE5's Avatar
The next installation involved the stainless-steel DC Sports header. Because the header is designed as one piece, installation was a little more difficult than a standard two-piece header. Temporarily removing the slave cylinder (12mm bolts) and the radiator bracket (10mm bolts) allowed us to get the header in place without doing any damage to the fit or finish. Once the header was in place and the slave cylinder and radiator returned home, we turned the wheels of the Dynojet to 126.1 hp and 116.4 lb-ft of torque. Overlaying the graphs shows that more power was gained in the 2000- to 4000-rpm region, with another overall gain continuing all the way to the redline from about 5500 rpm. Peak torque output decreased slightly, but range areas from 2000 to 4000 rpm and again from 5500 to redline were increased slightly. Since ignition timing had become an issue with the newly installed high-comp pistons, we opted for a performance bolt-on ignition system that would help clean up the sputtering and spiking of our new powerplant. The next installation involved the stainless-steel DC Sports header. Because the header is designed as one piece, installation was a little more difficult than a standard two-piece header. Temporarily removing the slave cylinder (12mm bolts) and the radiator bracket (10mm bolts) allowed us to get the header in place without doing any damage to the fit or finish. Once the header was in place and the slave cylinder and radiator returned home, we turned the wheels of the Dynojet to 126.1 hp and 116.4 lb-ft of torque. Overlaying the graphs shows that more power was gained in the 2000- to 4000-rpm region, with another overall gain continuing all the way to the redline from about 5500 rpm. Peak torque output decreased slightly, but range areas from 2000 to 4000 rpm and again from 5500 to redline were increased slightly. Since ignition timing had become an issue with the newly installed high-comp pistons, we opted for a performance bolt-on ignition system that would help clean up the sputtering and spiking of our new powerplant. The Direct Hits ignition kit came with new Bosch resistor-type plugs that we gapped at .032-in. for our normally aspirated motor. After the inline resistors were installed on top of the spark plugs, the engine ECU was reset (according to manufacturer specifications) and we ran the car on the dyno. We expected a much cleaner graph, void of the spikes, peaks and valleys that plagued our other graphs, and that's what we got. Peak power output rose to 126.9 hp, with torque maxing out at 116.9. However, looking at the graphs, you can see the power gain was pretty consistent across the board and, more importantly, helped eliminate a lot of the spiking we had encountered before
This is what I found on google. (information pertaining to direct hits in red) http://www.importtuner.com/powerpage...it_powerinteg/
Old Mar 17, 2006 | 05:19 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
more and more
my03maxima
Jul 28, 2024 07:40 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
