Alot of vibration...
Old Mar 19, 2006 | 09:39 AM
MaxgtrBlue's Avatar
I was driving yesterday with no problem to JFK, After picking up the person, Driving home i noticed alot of wheel vibration and shaking with some noise coming from drivers side front wheel. I didnt hit any potholes or anything.
Now it wont stop. its especially noticeable at 55-60mph the car pulls to the left side but that was always like that, What would make it vibrate like this..
thanks
Old Mar 19, 2006 | 10:06 AM
MaximaPolak's Avatar
Bearing maybe...those make noise when they go bad.
Old Mar 19, 2006 | 10:10 AM
MaxgtrBlue's Avatar
with vibration? i notice if i turn the wheel a certain way it makes more vibration
Old Mar 19, 2006 | 10:35 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
this is the same that it is happening to my 94 toyota daily driver... it is the balljoint that it is bad... I will change it one of these days....
Old Mar 19, 2006 | 11:56 AM
irish44j's Avatar
retired moderator
could be a balljoint, tie rod end, wheel bearing, or one of the balancing weights came off your wheel....put the car on jacks and check for play in the balljoint and steering tie rod. If they feel tight, hold the wheel at the 12 and 6 positions and wiggle, checking for bearing play. Then look at the wheel and make sure all the balancing weights are there.
Old Mar 19, 2006 | 04:52 PM
MaxgtrBlue's Avatar
Thanks, I actually did the wheel push while the car was on the floor and i heard this clicking sound on one side. at first i thought the lug nuts were loose, they werent so its more likley the ball joint right? Thanks!
Old Mar 20, 2006 | 08:18 AM
k2max_driver's Avatar
if you jack your car on that wheel you can figure out which one is bad up and play is the ball joint, side to side play is tie rod end, and the entire wheel moving with no signs of damage to your joints, its the wheel bearing. i just replaced my passenger side wheel bearing and outer tie rod end.
Old Mar 20, 2006 | 10:21 AM
MaxHind's Avatar
I had my wheels rotated a few months ago, and they didnt balance them. my car viberated around 60mph and wouuld go in and out. I have new wheels now, but still... Im pretty sure that was the problem for me, now its gone that i have new wheels. Good luck
t6378tp
Sep 29, 2018 04:27 PM
Tmax78
Sep 25, 2015 09:07 PM
MaxRPM6
Sep 11, 2015 06:56 PM
ballerchris510
Sep 10, 2015 09:35 PM
