nothing works!
Old Mar 20, 2006 | 04:49 PM
MaDxKiLLa's Avatar
nothing works!
This may sound really stupid but i was installing angel eyes and my friend had a plier on the wire when i turned the lights on and there was a huge spark. Now all my wedge bulbs dont turn on my dashboard light that lights up the speedometer wont turn on, none of teh sidemarker lights, or license plate lights work....what do you think the problem is? Fuse? LIghtbulbs are fried? both?
Old Mar 20, 2006 | 05:00 PM
Hoooper
look for a fuse, check the big one next to the positive terminal on the battery. after fuses check relays.
Old Mar 20, 2006 | 07:07 PM
MaDxKiLLa's Avatar
so bulbs are most likely fine?
Old Mar 20, 2006 | 07:16 PM
MaDxKiLLa's Avatar
which number is it on the fuse box they all seem to be fine its one of the headlamp fuses right??
Old Mar 20, 2006 | 08:13 PM
bugbite77's Avatar
when you tapped into the clearance light for the accessorie, did you tap into the green wire with white stripe or black wire?
Old Mar 20, 2006 | 08:51 PM
MaDxKiLLa's Avatar
i tapped into green and white i have the ebay projector not HIDS..
Old Mar 20, 2006 | 08:55 PM
MaDxKiLLa's Avatar
i think it is because the metal pliers were touching it when I turned the light on, there wasa spark
Old Mar 20, 2006 | 09:01 PM
NYPD-Arnold's Avatar
Z
You blew fuses.
Old Mar 21, 2006 | 05:39 AM
Dr. Roy's Avatar
you blew a fuse, its in the box on the drivers (front) side of the engine compartment
Old Mar 21, 2006 | 01:09 PM
scheibler's Avatar
yep, its the fuses for sure....I had the sameproblem installing a headunit in my 2k max except I blew the fuses to the lights on my a/c controls
Old Mar 21, 2006 | 10:56 PM
getbigtony's Avatar
err.. if u made a suggestion of the fuse, wouldn't u go about and check that out yourself first? it's not that hard to grab a testlight and take it out and look at it.
Old Mar 22, 2006 | 05:06 AM
qballjr13's Avatar
How is your buddy who was holding the pliers? ZAP!!
Old Mar 22, 2006 | 07:23 AM
MaDxKiLLa's Avatar
luckily the pliers had rubber handles so she was okay and it was the fuse thanks guys!
Old Mar 22, 2006 | 07:28 AM
meccanoble's Avatar
Sports Button FTW
lmao, a wasted thread. If you checked before posting....never mind cause u probably didnt know which fuse to check. Glad it all worked out. Don't u love it when the problem is easy to fix and very affordable
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Maxima30
Sep 7, 2015 06:13 PM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
