Creeking noise on rev
Old Mar 21, 2006 | 05:41 PM
Merlyn's Avatar
And... I'm out
Whenever I rev my engine, I get a creeking noise as the RPMs are dropping. I am still under my 5 year 60,000 mile warrenty and really want to know if this is an internal engien problem. I am at 58,3xx miles and if this is an internal problem then I need to get it to the shop to get a replacment. I asked a few guys at advanced auto parts and they said it doesn't sound like anything that would be coming from outside the engine so I figured that it must be internal. Called of Nissan and they said I was still under my 5 year warrenty. It happense sometims, when coming to a stop, or when just reving my engine. One of the guys asked if I had ever hit redline. I haven't but that question may be an answer to you what he may have thought it was. Anyway, thank you for all the input. Hopefully schduling an appointment within the next week.
Old Mar 21, 2006 | 08:59 PM
dch95's Avatar
Originally Posted by Merlyn
Whenever I rev my engine, I get a creeking noise as the RPMs are dropping. It happense sometims, when coming to a stop, or when just reving my engine. .
It almost sounds like the suspension causing the noise. Sit in the car with the windows up and engine off. Have a friend shake the car in all different directions and listen for a noise similar to what you here when the engine is revved.
Another idea is to have someone rev your engine for you while you listen for the noise with the hood up. It may be easier to hear that way.
Old Mar 21, 2006 | 09:04 PM
5thgenmaxima's Avatar
Does it do it while your sitting at a stand still or only while your moving?
Old Mar 22, 2006 | 03:01 AM
Merlyn's Avatar
And... I'm out
It does it both... I had read on here about creeks from suspension, so I sat still... and I have even tested it at high speeds and low... if I sit in 2nd gear, let off everything clutch / gas / brake, and I roll, the creek just goes (as the RPMs are dropping), if I am crusiing at 50 MPH, no creeking, I stick it in neutral rev, as it hits peak then comes down it creeks, again harder to hear when driving, had people look under the hood as I did it, they said it was internal... but all in all, no matter whether I am moving, sitting, or rolling, if the RPMs are dropping, it creeks..
Old Mar 22, 2006 | 11:47 AM
optimus1's Avatar
check tensioner pulley and tightening screw on that assembly.
also check Power Steering pump, etc ...
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
